Starting The Slate Floor Monday
Old 12-27-2008, 01:22 PM   #41
CJKarl's Avatar
Trade: Masonry
Re: Starting The Slate Floor Monday
Originally Posted by SLSTech View Post
Nice work - so was your XMas present to yourself, finishing it so that you didn't have to think about that floor anymore?
Yoou got dat right brotha.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 12-27-2008, 02:26 PM   #42
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Nice, very nice.
I'm curious how you handled the radiant heat floor in regard to your liability?
Was there a pressure test prior to your starting to verify it was working prior to your start and was there a test after you got done screwing down the CBU?
Mike Finley is offline
Old 12-27-2008, 03:53 PM   #43
raskolnikov's Avatar
Trade: masonry
Mr. Kaufman,
That looks like a million bucks, you should be oh so proud!!! Please post more photos showing your work and the work that seperates the men from the boys! As far as the rest of the chalet/hacienda, photos are a plus!
D.
raskolnikov is offline
Old 12-27-2008, 04:16 PM   #44
CJKarl's Avatar
Trade: Masonry
Originally Posted by raskolnikov View Post
Mr. Kaufman,
D.
I think we need some Perrault Masonrypics soon.
CJKarl is offline
Old 12-27-2008, 04:19 PM   #45
CJKarl's Avatar
Trade: Masonry
Originally Posted by Mike Finley View Post
Nice, very nice.
Thats all in the heating guys hands. They don't seem to be too concerned about the fact that if there is a problem it's going to be a NIGHTMARE to repair anything under that floor.
CJKarl is offline
Old 12-27-2008, 05:02 PM   #46
Chief Toilet Mover
You're kidding me? Unless the heating guys are totally brain dead don't you think they will drag you into it?
If I'm reading your right, as of right now, nobody knows if the floor has any leaks in it or not?
Old 12-27-2008, 06:13 PM   #47
CJKarl's Avatar
Trade: Masonry
I have been in contact with the heating guys and the GC from day one of the floor. The floor hasn't been holding pressure since the start. I was giving the go ahead by the owner of the heating co. to continue. Sounds screwy, but believe me it's WELL documented.
CJKarl is offline
Old 12-27-2008, 06:20 PM   #48
Chief Toilet Mover
OH my!
They covered the floor up knowing it wasn't right! Guess you didn't even need to worry about marking the lines.
Just kidding.
Old 12-27-2008, 06:24 PM   #49
Professional Instigator
rbsremodeling's Avatar
I have done 12 of heat floors and 6 of them did not hold pressure when tested. When they actually where filled and turned on not a leak.
There seems to be a problem IMO. Something wrong with the process of testing for leaks. They never seem to hold air pressure half the time. I have seen a few post talking about it here and my ac guy has had it happen several times that the air test failed but the system worked just fine.
rbsremodeling is offline
Old 12-27-2008, 07:56 PM   #50
Chief Toilet Mover
I did some reading and it seems that it's common to test these systems at 100 psi using air but they are designed to function at about 20 psi when running.
Sorry to hijack your thread - (slate looks awesome) I'm curious about how the industry handles this.
Old 12-29-2008, 01:54 PM   #51
CJKarl's Avatar
Trade: Masonry
I guess that's why they're no too concerned...I still am.
CJKarl is offline
Old 01-01-2009, 04:00 PM   #52
design build
javatom's Avatar
Trade: general
The infloor heat may cause some movement. I'm curious, was the durock put down with mortar or thinset?
javatom is offline
Old 04-07-2010, 05:07 AM   #53
D-TEK's Avatar
Trade: General Construction
The floor looks great! Everything that you put into that job, was worth it!
D-TEK is offline
Starting a new business - advice wanted Panzer5 Business 28 08-03-2009 07:01 PM
need help starting my business i got stupid start up questions USER8493893 Business 10 09-27-2008 11:24 PM
Artificial Slate... 2ndGen Roofing 0 08-19-2008 01:53 AM
Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof Roof Cleaning Roofing 3 07-04-2008 01:21 PM
Ungaged Slate Flooring CJKarl Masonry 0 03-01-2007 08:13 AM
