Removal Of Fireplace Insert
My Mother wants to remove the insert from my Grandparents full masonry fireplace. I have no knowledge of this, but want to remove it. No idea of the make or model. Any help?
Trade: Masonry
Re: Removal Of Fireplace Insert
sry Tscar thats not my field(( inserts)) lol but my suggestion is hook a chain on it and attach to ball hitch and gas it lol
Trade: General Contractor, Remodeler
The flu has very likely been removed or otherwise butchered for the original install, if it was installed correctly. remove the face of the insert and investigate... couple of screws or? I wouldn't want to be the one to rebuild the flu.
Trade: Masonry / architectural stone carving
Some times the smoke shelf is chopped out to get the flue pipe from the insert to fit
Any one else here ever rebuild a flue from inside the chimney?? Now thats a lot of fun. really have to have faith in your top side helper ![]() JVC |
Trade: masonry
i sold inserts and wood stoves for several years,and installed them.im not saying this is how they did it or not,but we always wired the damper open,then installed the insert.in this manner the fireplace was never damaged and it could be used again when whoever wanted to get rid of the insert.
my suggestion cover flooring with heavy duty tarp.have a cart about the same heighth of hearth ready.pull the insert out a little and remove the surround(if it one that can be removed.you might want a shop vac handy to suck up soot and other crap.pull insert all the way out and sit on cart and remove from the room.insert is going to be heavy,so it is a two man job. good luck
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Trade: Renovations
What stacker said, and definitely have a shop vac handy and plugged in, there will be a lot of crap, fine soot and creosote on top of it. Also, if you put down some strips of plywood or lath, you can lift the leading edge onto a piece of copper pipe (or two) across the strips and roll it out. Those things can be very heavy.
I've had to rebuild the smokeshelf after pulling inserts before, as John says it ain't much fun.
#7 | |
Trade: Masonry
Re: Removal Of Fireplace InsertQuote:
Good deal. I suspected as much so with your information was able to talk her out of it. Pops is a happy man, and so am I. S!
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Fireplace Insert Raised off the Slab | Hambone | Masonry | 14 | 04-22-2007 09:54 PM |
| Fireplace Insert Raised off the Slab | Hambone | Construction | 7 | 04-20-2007 11:57 PM |
| Electrical for fireplace insert | Mike Finley | Electrical | 22 | 05-13-2006 10:26 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
