Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry > Masonry Picture Post
Old 10-16-2008, 08:19 PM   #1
Captainsls's Avatar
Trade: HARDSCAPE
Raised Patio
I figured I would share our current project. I would love to get any input, comments or questions are welcome. House was built in 1809
Captainsls is offline   Reply With Quote
Old 10-16-2008, 08:24 PM   #2
Captainsls's Avatar
Trade: HARDSCAPE
more........
raised-patio-ritchie3.jpg   raised-patio-ritchie5.jpg   raised-patio-veneer1.jpg
Old 10-16-2008, 08:28 PM   #3
Captainsls's Avatar
Trade: HARDSCAPE
more to come as we progress
Old 10-17-2008, 05:13 AM   #4
CJKarl's Avatar
Trade: Masonry
1809...so it's a new house. Alot of homes here are from the 1750s. Worked on one that was built in 1665.
Patio looks nice, what are you capping the wall with?
There's Always A Market For Quality
CJKarl is online now   Reply With Quote
Old 10-17-2008, 11:43 AM   #5
Trade: Mason
Send a message via AIM to Tommy C
Are the block filled in solid?
Tommy C is offline   Reply With Quote
Old 10-30-2008, 06:04 PM   #6
Captainsls's Avatar
Trade: HARDSCAPE
We filled the cores with grout, although I’m not sure it was entirely necessary. Would you have done the same?
Old 10-30-2008, 06:10 PM   #7
Captainsls's Avatar
Trade: HARDSCAPE
Here is where we are thus far. We are moving slowly with only 2 of us. CJ, we used (heavy) thermal blue for the caps as you can now see in the picts.
Old 10-30-2008, 07:07 PM   #8
Trade: masonry
Captain,
What happens with the footing at grade at the bottom of both sets of steps? Removed afterwards?
D.
raskolnikov is offline   Reply With Quote
Old 10-30-2008, 07:16 PM   #9
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Construction
Nice, what program did you use to design it?
Total cost of the job?
Midtown Tulsa Remodeling
Cole is offline   Reply With Quote
Old 10-30-2008, 07:35 PM   #10
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
Nice work in progress. What happened to the purple rocks??
rbsremodeling is offline   Reply With Quote
Old 10-30-2008, 07:51 PM   #11
Mod / ArchiBuilder
Cole's Avatar
Zing!
Old 10-30-2008, 08:15 PM   #12
Captainsls's Avatar
Trade: HARDSCAPE
Thanks for the compliments. As for the footing, we will just run some cuts down it with the demo-saw and remove the top 6” to allow for turf to grow. In regard to the design, many programs were used to get the final render, but sketch-up is responsible for the layout.
By purple rocks I’m guessing you mean the ones shown in the design? I guess it turns out that bluestone is actually blue.
Old 11-04-2008, 07:02 PM   #13
Captainsls's Avatar
Trade: HARDSCAPE
Almost done. Laying the flagstone. Natural cleft full color pattern bluestone. The 2 of us can lay about 200 sq a day (that’s with laying it twice, once for position and another individually leveling each piece)
Old 11-04-2008, 07:09 PM   #14
Mod / ArchiBuilder
Cole's Avatar
Nice work!
Old 11-05-2008, 11:16 AM   #15
Trade: Mason
Yeah, I'd fill the block cells with grout.
Old 11-05-2008, 02:33 PM   #16
Trade: Landscaping/Hardscaping
Looks great so far!
I'm just wondering exactly how these kinds of patios are done. Is the bluestone just set into stonedust? Is there any other kind of base below that?
Thanks for the info!
bls1000 is offline   Reply With Quote
Old 11-05-2008, 05:55 PM   #17
Captainsls's Avatar
Trade: HARDSCAPE
This situation is somewhat unique as far as the base is constructed. We are overlaying an existing concrete slab, but we also extended the patio beyond the slab. That part is filled with aggregate. As far as your base construction I don’t know what material you should use? Use whatever meets astm-2940 and achieves compaction, for us reprocessed asphalt is proper road base aggregate. I would never use stone dust for base in any situation. However, for a 1/2" bedding layer to seat the stone we do use screenings.
Old 11-05-2008, 06:42 PM   #18
Do you spread the screenings in between the joints too?
Finished product looks great by the way.
Old 11-05-2008, 08:00 PM   #19
Captainsls's Avatar
Trade: HARDSCAPE
You could, but if you want to step it up a notch you could use polymeric sand that is recommended for natural stone applications.
Old 11-26-2008, 05:00 PM   #20
DILLIGAF
doubleaction's Avatar
Trade: Decorative Concrete, Remodeling, Decks
Looks realy good
Eric Swanson
http://www.carpenterology.tripod.com/Remodeling, Decks, ect.
Trinity Concrete LLC. Decorative concrete. Stamped concrete, vertical stamped concrete ( we are a Flex-c-Ment certified contractor) overlays, ect.
doubleaction is offline   Reply With Quote
Pebble stone patio jtfussell Ceramic & Stone Tile 13 05-23-2009 08:26 AM
Patio & spa pad over fill questions deckman22 Concrete & Paving 4 01-27-2008 06:14 PM
Tarring foundation for raised patio... ruskent Masonry 4 04-06-2007 03:00 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Patio Expansion andy998 Masonry 6 08-20-2006 05:32 PM
