Paver Steps
Old 09-24-2008, 10:09 PM   #1
New boots
Patricks's Avatar
Trade: Paver Patios
Send a message via Yahoo to Patricks
Unhappy
Paver Steps
Hello all. I have enjoyed reading the posts. Very valuable real life education. Thank you.
As a new comer to the paver patio business I have a question about paver patio steps. In the past there were either none or the HO just wanted wood.
What is the most solid/quality way to secure them? These will be free standing. I'm just not sure about the back fill in the core.
Thanks for all your help.
Patricks is offline
Old 09-24-2008, 10:12 PM   #2
Tscarborough's Avatar
Re: Paver Steps
They should be made solid of a complementary SRW, not made out of pavers, for the best solution. Pavers are for flexible pavements, not stairs.
Tscarborough is online now
Old 09-25-2008, 01:07 AM   #3
New boots
Patricks's Avatar
Trade: Paver Patios
Re: Paver Steps
Understood. I didn't mean build the entire set of stairs out of pavers. The base will be stone wall with the pavers on top in a half circle. I will be at the site tomorrow and can send pictures as well as the inspiration steps that a friend had done. There will be three steps. Is it best then to pour concrete for the center portions?
Patricks is offline
Old 09-25-2008, 08:03 PM   #4
AtlRemodeling's Avatar
Trade: Residential Remodeling
Re: Paver Steps
Patricks,
We have built a number of steps from paver/block combinations. Usually our base is built out of concrete block and then we use mortar (sometimes hydraulic cement to bond the pavers to the tread and even the riser. I am in the south so we do not have a problem with the cold that you may have in Ohio.
We have also used the SRW as Tscarborough suggested.
AtlRemodeling is offline
Old 09-25-2008, 09:02 PM   #5
Re: Paver Steps
I don't recall every seeing a set of steps topped with pavers that looked good. They are designed to be visible on the top surface only, not the edge. All good SRW manufacturers produce cap units that can be cut to produce steps/landings. At the very least, consider the caps as an edging with paver infill (the base and body can be solid SRW or poured concrete (plan on a footing).
Old 09-25-2008, 10:17 PM   #6
Re: Paver Steps
Here is one example of pavers as both the risers and the treads that we installed for a client. The owner was delighted with the outcome.
Old 09-25-2008, 10:27 PM   #7
Re: Paver Steps
Yep, looks great. Nice work.
Old 09-25-2008, 11:13 PM   #8
New boots
Patricks's Avatar
Trade: Paver Patios
Re: Paver Steps
That's exactly what I wanted to do. Thanks you both for your input. I had seen it done before so I didn't think too much of it. I couldn't find any documentation on the process. Now I am second guessing my self as to how I want to fill the inside for a lasting set of steps.
Having trouble uploading. I have a pic in the folder "example".
Patricks is offline
Old 10-08-2008, 09:54 PM   #9
WARD's Avatar
Trade: masonry
Re: Paver Steps
We are finishing up some pavers where we used a pool coping for the treads that matched the pavers we are using. They turned out looking good. Here is a picture, but I'm not sure how good it is though.
WARD is offline
My Steps are collapsing tbruening Landscaping 25 07-29-2008 12:04 PM
What is the proper way to install brick steps against the band around the house? TurnkeyConst Masonry 12 03-12-2008 04:33 PM
I've got some problems with poplar steps that I stained Dorman Painting Painting & Finish Work 20 12-30-2007 09:10 PM
resurface concrete steps haskl33 Masonry 0 10-04-2006 10:13 PM
Question about sandblasting some metal steps Dorman Painting Painting & Finish Work 3 06-10-2006 12:21 AM
