Trade: Stonemasonry
Oversized Mantel
Here's a sequence of installing a 2,700# stone as a mantel, 12 ft. in the air, inside a house.
Bill Baddorf Bill@artisanstoneworks.net www.artisanstoneworks.net www.stonefoundation.org |
Trade: Masonry
Re: Oversized Mantel
I have a 1400 LB mantle coming up. I told the quarry to cut it into thirds.
Trade: Construction
Good job! That's a beefy looking lift, too - must'a been a job just getting the lift itself set up and into place...
Was that a manual come-a-long or is there a motor I'm not seeing? Mac |
#4 | |
Trade: Railing
Re: Oversized MantelQuote:
artisanstone, That looks a bit scary! Is that your hoist, or rental? Will the center of mantle be supported when done? I'm not a mason, but that thing would be bad news if the mantle center cracked at a later date! Thanks for posting picts. I used to do a fair amount of crane work when framing for 20 years. I was taught to always use a spreader above the load. It distributes the weight evenly over the load, keeps the pull line square to the load, keeps load level, stops chains from sliding, & is simply much safer. It's easy to do, & is cheap insurance to keep from losing control at an inopportune time. I would have either used either all chain to lift, or all straps, so as to not have strap stretch more than chain when lifting. Obviously you "got r done" so all is well! Joe |
Trade: Stonemasonry
I guess it does look a little bit redneck.
That is my bridge crane. I had an engineer friend design it specifically for this job and I purchased the materials/built it. I used the chain for the lifting and the strap was just backup. I was a little nervous when I did this (3-4 years ago) just thinking of the possibilities. The hoist is manual, and rated for 3.5 metric tons. It attaches to a 4,000# trolley which hangs from a cross beam which is supported in turn by 2 2,000# trolleys. Essentially, I can move the stone back and forth as well as forward and back. I built columns up below the subfloor to carry the weight. I think next time, I may just set the crane on heavy sleepers and spread the load over a bunch of joists.
Trade: Stonemasonry
BTW, My next goal is to build an entire fireplace out of stones this size/weight. I just need the right client.
Trade: Railing
artisanstone,
You did a great job on building that hoist! Nothing redneck about it! I was wondering how you get the beams & trolly set above the posts. That must be the hardest part of setting up. I was kinda wondering myself what you were bearing it on, before you posted about shoring it up to floor below. That is one nice looking fireplace! ![]() Joe |
Trade: Stonemasonry
In the last pic you can see the smaller hoist arm we use on scaffolding. It sometimes has a winch mounted on it, sometimes a pulley. We used that to lift the components of the crane. The crane is designed to use regular scaffold x-bracing to keep from racking.
Trade: Masonry
Just checked out your website. You do some way cool stuff.
Trade: Masonry
A lot of that stuff, you just can't use a level and strings.
It is what it is
Trade: Roofing, Remodeling, Concrete
If you had some 4x4, braced with 2x that would be redneck.
Patriot Broadcasting Network |
| Boren Oversized? | Good Stuff | Masonry | 4 | 01-07-2007 01:12 PM |
