My Christian Church Sign
Old 03-24-2008, 08:52 PM   #21
Tscarborough's Avatar
Re: My Christian Church Sign
Let it dry out. Once it has dried for a month, and you have a week to let it re-dry, clean it with a proprietary cleaning solution and a hose, then let it dry for a week and seal it. Problem solved.
From the looks of it, I would use SureKlean 800 detergent or 101 lime solvent at about a 10 to 1 ratio, then seal it with Prime-A-pell 200. Any similar products should work fine.
Tscarborough is offline
Old 03-24-2008, 09:06 PM   #22
master mason's Avatar
Trade: masonry
THX , Have you ever worked with this stone before? I liked it ,It was cut in nominal sizes of 4-6-8-10-and12 inch high pieces.It cut were I wanted it to with a carbide tip broadhead.The hardest part was the compound corner stones.I set the sign first on pipe columns that were Hilti bolted to the footer.I drilled 1/8" holes in the bottom of the sign 1" in on the corners and put jack lines on the 4 corners down to the cmu corners.
master mason is offline
Old 03-25-2008, 09:33 PM   #23
It is a nice evenly bedded stone. It is part of the Austin Chalk group. To really learn how to use it, ask JVC.
Old 03-26-2008, 08:19 AM   #24
stacker's Avatar
Trade: masonry
Originally Posted by master mason View Post
NO WAY! I go every Sunday to worship,I'm a good Christian.
i used to go to whatever church was building a new building!
stacker is offline
Old 04-07-2008, 09:45 PM   #25
menber
masonking02's Avatar
Trade: bricklaying
nice work
masonking02 is offline
Cheap Tips On Surviving An Economic Slowdown Ed the Roofer Marketing & Sales 9 03-13-2011 10:27 PM
Do you sign the subs contract or make them sign your sub agreement? wackman General Discussion 37 02-29-2008 03:29 AM
I think i went overboard on my job site sign! ruskent Marketing & Sales 21 02-21-2008 04:40 PM
Church Bulletins MattCoops Marketing & Sales 10 01-14-2008 12:04 PM
Sign In A Store Window dayspring Off Topic (Non Trade) 16 09-20-2006 09:29 PM
