Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry > Masonry Picture Post
Old 10-04-2009, 09:09 AM   #1
jgray152's Avatar
Trade: Faux Rock Creations
Carved Concrete Walkways/Patios
No stamped concrete. This is all carved with a grinder
jgray152 is offline   Reply With Quote
Old 10-04-2009, 11:04 AM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
So you pour and then mark your grout lines with a pencil or something and then grind out with a grinder and diamond blade? I am guessing that you stain the different colors to achieve the look of cultured stone.
The real question is can you be competitive with cultured stone? Or even better, can you get more for the job?
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline   Reply With Quote
Old 10-04-2009, 11:48 AM   #3
jgray152's Avatar
I have never used cultured stone before so I have no experience but I am guessing since they are a manufactured unit that have a system for going together.
I try to mimic real stone like cultured stone does. The grout lines created you can't get with cultured stone.
I am guessing cultured stone you lay dry on a packable base?
You can make a lot of profit this way since there is very little labor involved. I could be done in 2 days all carved and colored.
I can't speak against manufactured stone because I have never installed it before.
I don't like "systems" to follow or being stuck with a specific size, shape or style. The way I do it allows a lot more freedom. You can have very large flag stones, over 4-5' across in areas maybe for landings and small and very small ones in other areas. I am not sure if you can get such large variances with manufactured stone systems.
You can mark it with a pencil but I often just grind by eye. Marking the lines first do make it go by faster though
Old 10-04-2009, 07:00 PM   #4
dakzaag's Avatar
Trade: mason
I guess I should clarify that cultured stone would not be a great option for a walkway as I am not aware of manufactured stone that is durable enough for a walking surface.
It seems like a time consuming process to grind patterns and stain seperately to achieve some different colors.
What about the cracks and control joints?
D K & Sons
Old 10-04-2009, 07:20 PM   #5
jgray152's Avatar
I can usually grind a whole patio or walkway in under 30 minutes and color 30-60 minutes.
The conctrol joints are placed within the grout lines and then filled with crack filler to hide them. We do this every 5 feet and eliminates the possibility of cracks.
We use wire mesh reinforcement within the concrete.
Old 10-04-2009, 07:27 PM   #6
Trade: Remodeling general
How does the exposed aggregate in the grout joints hold up. I would expect a fair amount of spalling given your location. How long have you been doing this process?
naptown CR is offline   Reply With Quote
Old 10-04-2009, 08:36 PM   #7
jgray152's Avatar
It holds up very well. No issues at all. There are walkways over 10 years old holding up fine.
Old 10-04-2009, 08:42 PM   #8
DavidC
DavidC's Avatar
Nice work. Where did the idea come from?
Good Luck
OK, rant if you must. For the love of Pete, use paragraphs and spell check.
DavidC is offline   Reply With Quote
Old 10-04-2009, 08:42 PM   #9
jgray152's Avatar
The vertical concrete portion for the grill was stacked without forms and carved with trowels when the concrete was still wet.
I was trained from a guy locally. He has been doing it for years.
Old 10-04-2009, 08:44 PM   #10
jgray152's Avatar
Here is another picture.
Old 10-06-2009, 09:42 PM   #11
jgray152's Avatar
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 39 09-19-2009 09:08 AM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
Spalling concrete stabilization tsunamicontract Concrete & Paving 4 06-07-2009 07:51 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
