14x16 Patio
Old 08-26-2008, 11:24 PM   #1
06 F150's Avatar
Trade: That's what she said
14x16 Patio
That's what she said...
06 F150 is offline
Old 08-26-2008, 11:26 PM   #2
Patrick's Avatar
Re: 14x16 Patio
was there a sale on orange cones?
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 08-26-2008, 11:36 PM   #3
06 F150's Avatar
Re: 14x16 Patio
06 F150 is offline
Old 08-26-2008, 11:53 PM   #4
Tscarborough's Avatar
Re: 14x16 Patio
It looks good, but what kind of magic do you use to suspend that brick?
Tscarborough is online now
Old 08-27-2008, 12:16 AM   #5
Re: 14x16 Patio
Wondering that self-same thing.
Also where is this that they don't
use cap block?
neolitic is offline
Old 08-27-2008, 12:43 AM   #6
06 F150's Avatar
Re: 14x16 Patio
06 F150 is offline
Old 08-27-2008, 08:19 AM   #7
Re: 14x16 Patio
Originally Posted by 06 F150 View Post
I am in Minnesota
The brick sat suspended all by themselves, ya I don't know how they stayed that way... I add the 4x6's just to be safe until I poured the concrete. The next day I went back and mortared in the bottom row of brick that sat on top of patio.I used two pieces of expansion joint on top of the patio for the patio to move during the seasons and not bust out the mortar.
I will get a pic of it, as I need to go over there and discuss some landscaping the home owners want done.
You really need to cut a joint
around that brick line.
It should rest only on the brick ledge,
not on the flat work, which will move.
I've seen it over and over, either the
flat work, the brick, or both will crack
when your concrete heaves on the
outside edge.
They must have laid the brick on an
angle iron to keep it isolated from
the concrete work to begin with.
neolitic is offline
Old 08-27-2008, 12:38 PM   #8
06 F150's Avatar
Re: 14x16 Patio
06 F150 is offline
Old 08-27-2008, 05:30 PM   #9
Tommy C's Avatar
Trade: Mason
Send a message via AIM to Tommy C
Re: 14x16 Patio
No expansion/control joints on the slab? Also, did you put a gravel base down?
Tommy C is offline
Old 08-27-2008, 11:31 PM   #10
06 F150's Avatar
Re: 14x16 Patio
Re-read my previous post on the control joints
I did not put gravel down as the base was already well compacted undistributed earth.
06 F150 is offline
Old 08-27-2008, 11:44 PM   #11
General Contractor
Snow Man's Avatar
Trade: Construction Management
Re: 14x16 Patio
wHERES THE CONCRETE WIRE? COMES IN A ROLL.Whats with the rebar ---few and far between???
Different freeze/thaw cycle A N D codes ....huh?
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 08-28-2008, 12:49 AM   #12
06 F150's Avatar
Re: 14x16 Patio
06 F150 is offline
Old 08-28-2008, 01:33 AM   #13
genecarp's Avatar
Re: 14x16 Patio
looks nice and neat, good job
genecarp is offline
Patio to Office Remodel balanceact Remodeling Picture Post 6 07-21-2008 01:46 PM
Backyard Patio masterplumber Concrete & Paving 1 05-09-2008 02:49 PM
Patio & spa pad over fill questions deckman22 Concrete & Paving 4 01-27-2008 06:14 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Patio Expansion andy998 Masonry 6 08-20-2006 06:32 PM
