Your Preference ABS Or PVC?
Hey guys I figured I would ask the plumbers out there, their favorite pipe choice. Although since I am not a plumber I have never touched pipe before
J/K So what are you guys preferences and why? The plumbing and rain drains I have done I usually like to use ABS. Not really sure why though, other than PVC is a little more brittle in my opinion. Both are allowed around here by code.Dave |
Trade: Residential Remodeling / Renovations
Re: Your Preference ABS Or PVC?
Around here Abs is for above ground (inside buildings) applications and pvc is for below ground applications.
Pro Plumber
Trade: Plumber
ABS
Lighter, can forced it into joist bays or inside floor joist bays easily, it has a better glue bond the pvc has, joints won't give out when hot water runs through the pipe like pvc will. |
Pro serviceman
Trade: Plumbing service/repair
I've seen PVC hold up better than ABS over the years, especially fittings. My old man was one of the first in our area to use ABS back in Ryan Homes experimental days. PVC takes expansion and contraction much better than ABS. Quieter in the walls too. PVC takes alot more time to install than ABS for the same reasons Ron mentioned. PVC is better quality overall when assembled properly.
The Grand Wazoo
ABS is not allowed for above grade installation here.
Service Manager
Trade: plumbing
PVC is denser than ABS. you can't hear as much noise from PVC pipe as you can from ABS. I've done remodels on 5 and 6 story buildings all done in PVC. I could never tell if someone was using the plumbing, except when the toilet was pulled. If you can hear sloshing in the wall, that's Acrylonitrile Butadiene Styrene for ya!
Thanks for the replies guys,I guess it is just like a ford vs. chevy type of thing
Are any of you guys required to use anything else for above ground, other than ABS or PVC?Sewerologist, where are you in PA? Dave |
Moderator
Both are allowed here under our code, but I prefer PVC as it will not propagate a flame as will ABS.
We also use quite a bit of service weight cast iron.
Allrounder Home Services
Trade: Painting, Remodeling, Handyman
Both are allowed here. My plumber told me that he uses ABS because it's faster to install.
#10 | |
Pro serviceman
Re: Your Preference ABS Or PVC?Quote:
ABS is not allowed underground in many munincipalities around here although I recently replaced an underground in Allegheny County with ABS and they had no problem with it. I'm still getting rid of old stock. |
Plumber / Carpenter
No ABS allowed here unless its repair to existing. My preference is PVC. Takes longer to install, but much, much tighter joints, quieter, and will keep its shape. Just look under trailers! With ABS run horizontal above ground it WILL sag between the hangers over time making one hell of a roller coaster ride for the water. (Again, just look under some older trailers)
Trade: Plumbing
We use PVC But in the walls from over head to basement I install C/I stacks. to deaden the sound in the walls. Of course in custom homes only my builder loves me for it!
Have A Blessed Day! |
#13 | |
I am in the North Hills area ,Allegheny county. Yup around here they have no underground preference. I wonder why no ABS underground though in some places? Anyone know? Dave |
You'd be hard pressed to even find any ABS pipe and fittings for sale in my area.
Thats weird, the differences in different areas, around here a lot of the plumbers use ABS.
Dave |
Handle It!
ABS does not melt as well as PVC, Therefore the joints are less unified.
| Government Contract Work - Service Disable Veteran Preference | FWConstGrp | General Discussion | 22 | 10-20-2009 08:36 AM |
| Trailer door preference | Webs | Vehicles | 44 | 09-18-2009 01:01 AM |
| 6yr old Certainteeds and shingle brand preference | jstrand23 | Roofing | 17 | 01-21-2008 01:04 PM |
| Construction Adhesive Preference? | Syborg_97 | Framing | 3 | 08-29-2007 08:31 PM |
| Preference: Work alone or with a crew? | Toothpick | General Discussion | 24 | 03-03-2007 08:34 PM |
