my own boss
Yeti In My Wall
dont know if this is considered diy, but i just bought a house and at first when i flushed the toilet it sounded like a baby yeti in the wall. it seemed the more it was used the quieter it was getting, even to the point of no noise after a few flushes. got up this mornin and now theres like a full grown bigfoot in my floor. i have no clue about plumbing other than it flows downhill. could it be the wax thingy????
i only work off drawings |
Pro Plumber
Trade: Plumber
Re: Yeti In My Wall
Not the wax ring.
It is a DIY Question though, make sure the water is turned on all the way, most sounds caused at or near the toilet has to do with flow of water, could be a defective fillvalve also. Could be high water pressure also, could be water not turned on all the way, could be loose washer in the shutoff valve, try making adjustment of water flow at the shutoff, see it that tells the story first. If none of these choices help, post more over at DIY Chatroom. |
Custom Builder
Re: Yeti In My Wall
Don't tell me.....I think I can get this one......Your mute, bed ridden, grandfather lays in the bed of the room just beneath the toilet. Check to insure proper closet flange to pipe connection.
![]() Bob
Bob |
OsNap
Guest
Posts: n/a
Re: Yeti In My Wall |
#5 | |
my own boss
Re: Yeti In My WallQuote:
thanks Ron just out of curiosity, did it become a diy because im buying the house?
#6 | |
Pro Plumber
Trade: Plumber
Re: Yeti In My Wall
Test the pressure on the house with a pressure guage that connects to an outside hose spigot. If it's 80psi or higher, thats a pressure problem, you don't need to solve the pressure problem before replacing parts in the toilet.
my own boss
Re: Yeti In My Wall
thanks Ron..
...i got this job im looking at that requires getting a waterline across a 18' garage. theres hot n cold already in the garage and the main runs perpendicular to the front of the garage. the front of garage is getting tore out for a drain. would it be better to t off the main and run it with the drain (i understand it has to be deeper) or cut the garage floor and run it straight across?
Pro Plumber
Trade: Plumber
Re: Yeti In My Wall
Which ever is more easier and cost effective.
Trade: plumbing
Re: Yeti In My Wall
super crew
not sure why you would want to run water lines underground. It is only aloud to be in the same trench as drainage if there are no connections underground. and even then it must be higher than the drainage pipe (19 inches i believe) |
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| Backyard office, retaining, and privacy wall | Team Scream | Masonry | 8 | 08-02-2007 11:27 PM |
| moving centennial wall | stacker | Masonry | 4 | 10-20-2006 12:12 AM |
| Roof sagging wall pushed out | christy | Roofing | 5 | 10-14-2006 09:53 PM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
