Winterizing Laundry Sink Sump Pump
Old 10-09-2017, 08:48 PM   #1
Willin's Avatar
Trade: Retired
Rewards Points: 396
Roughing in right now, new construction, summer vacation house in area with deep cold winter. Basement laundry will have washing machine discharge to utility sink adjacent, will raise discharge to main drain above using a 1/3 HP sump pump directly under sink drain.
We figure there is about 8/10 gallon of fluid left in total of drain line riser, the check valve, the "throttle" valve, the pump itself, and the sink drain atop the pump.
A gallon of RV antifreeze costs about $4.50 at Walmart.
Here's the plan and we invite your critique.
We'll switch the pump, rather than direct-wire it. We'll mark the switch, "leave on always except for winterizing."
To winterize, we'll pour two gallons of antifreeze into the tub, move our hand to the switch, and switch the pump OFF when most all the two gallons is pumped away, leaving a little antifreeze in the tub.
This should ensure the pump and all the inline PVC 1-1/4 DWV pipe, fittings, valves, the riser, etc. is all safe from freezing.
Anything else?
Willin is online now
Old 10-09-2017, 08:54 PM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,114
Re: Winterizing Laundry Sink Sump Pump
what about the washing machine?
"Your talent is God's gift to you. What you do with it is your gift back to God." - Leo Buscaglia
SmallTownGuy is online now
Old 10-09-2017, 09:06 PM   #3
Willin's Avatar
Trade: Retired
Rewards Points: 396
SOP for the washer. Disconnect hoses, drain, run RV antifreeze in rinse cycle, etc., etc.
Old 10-09-2017, 11:14 PM   #4
tjbnwi's Avatar
Rewards Points: 1,724
You need to pump the RV antifreeze through the washing machine. Use a waterbed pump, connect it to the water inlet hoses, slowly hand cycle the timer or run it through a cycle if digital. Lay the discharge hose on the floor pour a gallon of RV anti freeze in the drum, it should run out the hose.
http://www.waterbedoutlet.com/Electr...erbed-pump.htm
tjbnwi is online now
laundry sink in a garage that can freeze nickko Plumbing 11 04-29-2015 08:04 PM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 07:06 PM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
sink pump zbwmy Plumbing 1 11-11-2005 03:47 PM
