Winterizing Fridge With Ice Maker
Old 08-12-2012, 06:07 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,488
My family has a summer home and we need a new fridge. I'm pushing for one with an ice maker. We shut the house down and drain the water. Is there any possible way to drain an ice maker properly without getting too involved? Anyone had any experience with this? Thanks, Nick.
Morning Wood is offline
Old 08-12-2012, 06:17 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,854
Re: Winterizing Fridge With Ice Maker
Disconnect it.
KillerToiletSpider is offline
Old 08-12-2012, 06:23 PM   #3
Box Builder
Originally Posted by KillerToiletSpider
Disconnect it.
Ok, but will the water drain out or does it leave water in the system that can freeze and become issue. This is downeast Maine and subject to freezing temperatures.
Old 08-12-2012, 06:27 PM   #4
The Grand Wazoo
The only water an ice maker holds is between the angle stop and the solenoid valve in the fridge, disconnecting it is going to gravity drain that line.
Old 08-12-2012, 06:38 PM   #5
Box Builder
Damn. So nothing to worry about huh. Setup a ball valve with a drain on it and good to go.
Old 08-12-2012, 09:48 PM   #6
dkillianjr's Avatar
Rewards Points: 2,464
I do a lot of work in a community of summer cottages. A ton of people have ice makers on their fridges. Out of all the ones I have seen nobody has a drain on theirs. They just pull the fridge out and unhook the line. But I can't see how a drain wouldn't work.
dkillianjr is offline
Old 08-12-2012, 09:58 PM   #7
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,390
Our old tech used to have an attachment he would connect to his compressor and onto the water line when disconnected. He would turn the resume down to about 50psi and then use the water dispenser and turn on the ice maker. This would clear all the lines in a matter of seconds.
www.bcconstructionllc.com
BCConstruction is offline
Old 08-12-2012, 10:13 PM   #8
The Grand Wazoo
I saw no mention of a water dispenser in the original post.
Old 08-12-2012, 10:24 PM   #9
Box Builder
No water dispenser, but if there was one with a filter etc, would the compressed air be the way to go with that setup? Or would disconnecting and draining work with a water dispenser?
Old 08-12-2012, 10:39 PM   #10
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Disconnect the water supply and engage the dispenser until all the water drips out of the disconnected line.
ohiohomedoctor is offline
Old 08-13-2012, 12:07 AM   #11
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
I live in the northeast. Have a number of customers who I winterize cottages for.
A few plumbing & air fittings, a short hose, & an air compressor. Hook all up, pressurize the system to about 50 psi, & start opening lines / faucets. Work them in proper order. Once all water is blown out of the whole system, I open all taps a bit, just so if any moisture is still in & freezes, it doesn't explode the line.
RV antifreeze in all drains & toilets. Works just dandy here in NY & PA.
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Ice maker tapped into hot water tcleve4911 Plumbing 10 09-06-2010 10:33 PM
Advice for first built in fridge? TBFGhost Finish Carpentry 64 07-17-2010 10:37 AM
fridge tripping GFI dkillianjr Electrical 47 04-10-2009 07:46 AM
