Why Is The Clog Forming In The Top?
Old 02-09-2007, 07:00 PM   #1
PipeGuy's Avatar
Trade: underground
I cut open a bath tub drain today and noted that the top 2/3 of the pipe is developing a a grey colored build-up (presumably its soap scum, body oils, etc.). It's thickest right at the top of the pipe, about 1/4 - 3/8 of an inch thick.
Why does it form at the top?
PipeGuy is offline
Old 02-09-2007, 10:18 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Why Is The Clog Forming In The Top?
On the vertical or the horizontal run of pipe?
Ron The Plumber is offline
Old 02-10-2007, 12:18 AM   #3
Teetorbilt's Avatar
I'm assuming that it is the water level of the trap.
Albert Einstein
Teetorbilt is offline
Old 02-10-2007, 12:39 PM   #4
Squench's Avatar
Trade: Professional Plumber / Amateur Racer
I cut open many drains and the top always has the build-up
because the water flow is 'cleaning' the bottom portion. All the floaties
are sticking to each other. If you take a 'mini Mag' and illuminate a plastic continuous waste from behind, you will see the build-up at the top.
Squench is offline
storm sewer drop inlets dayexco Excavation & Site Work 7 06-04-2006 08:29 PM
