Whole-House Trap
Old 07-15-2008, 10:31 AM   #21
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Whole-House Trap
The purpose of a plumbing vent is to equalize the pressure in a plumbing system in order to protect the trap seals. That's it. There is no other purpose. It's purpose is not to "vent" sewer gasses.
(There is one specific, and relatively rare, vent that has another purpose. It is found only when using a whole house trap.)
The purpose of a trap is to prevent sewer gasses from entering the space. That's it.
(Again, a whole house trap may have an alternate purpose, but not always.)
22rifle is offline
Old 07-15-2008, 10:38 AM   #22
Rewards Points: 2,000
Okay, so this is all anecdotal but,
it's my experience from being on roofs,
that the smell around the vents is
both more pronounced and more odiferous
when connected to septic.
Further, a house where we did a deck
was almost unbearable outdoors in the summer,
and the HO had a septic outfit come in to replace
clay vit line from house to tank with PVC.
They also put in what was descrbed as,
and appeared to to be, a trap and clean out.
When they finished it was much more pleasant
to work back there regardless of the wind direction.
Was that all voodoo?
neolitic is offline
Old 07-15-2008, 10:40 AM   #23
22rifle's Avatar
was almost unbearable outdoor in the summer,
and appeared to to be a trap and clean out.
Yeah, it was all your imagination.
Kidding!
I don't like to use house traps but it would do exactly what you described.
22rifle is offline
Old 07-15-2008, 10:45 AM   #24
Kidding!
Thanks, that's why I thought that was their purpose.
I never thought about the un-trapped drain senario.
neolitic is offline
Old 07-15-2008, 09:48 PM   #25
Tom R's Avatar
Rewards Points: 2,036
Welp, - - the guy came out today and cleared the lines. I wasn't there, - - I was out ordering her siding and windows, - - but she said the clog was indeed right at the house trap, - - he cleared it out for about $300. And then he suggested she get rid of both the house trap and the house vent and just run a straight line (for another $1000, - - which she didn't go for). Although that was my initial call, too, - - logic tells me that killer is right, - - how can you be sure everything has it's own trap??
Tom R is offline
Old 07-15-2008, 09:53 PM   #26
22rifle's Avatar
A smoke test could clear that right up.
22rifle is offline
Old 07-15-2008, 09:56 PM   #27
Tom R's Avatar
The job is done and the sh!t is flowing freely again, - - but you're on, - - how do you go about 'clearing' things up with smoke?? . . .
P.S. That $1000 would give her up to 3 more clean-outs, - - I figure probably a good 20 years at least, - - she's 73 now . . .
Tom R is offline
Old 07-15-2008, 10:00 PM   #28
22rifle's Avatar
Cap off all the vents through the roof. Hook up a smoke machine (you can buy them made for this purpose) to the plumbing system (remove a trap at lav?) and let'er rip.
If smoke comes out into the house you know where there is an untrapped drain.
22rifle is offline
Old 07-15-2008, 10:06 PM   #29
Tom R's Avatar
Interesting, - - I've never heard of that . . .
Tom R is offline
Old 07-15-2008, 10:15 PM   #30
22rifle's Avatar
You can make your own. Pretty simple. PM me for a link if you ever need one.
22rifle is offline
Old 07-15-2008, 10:17 PM   #31
mickeyco's Avatar
Trade: Squirrel Handler
It's (the vent) purpose is to act like a vent, the same as the vent on a gas cap or gas can, that's why they call it a vent.
Main Entry:
2vent
Function:
noun
Etymology:
Middle English, anus, outlet, probably from Anglo-French, wind, draft, outlet
Date:
15th century
1: an opening for the escape of a gas or liquid or for the relief of pressure: as a: the external opening of the rectum or cloaca : anus b (1): pipe 3c, fumarole (2): hydrothermal vent c: an opening at the breech of a muzzle-loading gun through which fire is touched to the powder dchiefly Scottish : chimney, flue 2: an opportunity or means of escape, passage, or release : outlet <finally gave vent to his pent-up hostility>
— vent·less Listen to the pronunciation of ventless \-ləs\ adjective
mickeyco is offline
Old 07-15-2008, 10:24 PM   #32
22rifle's Avatar
Main Entry:
2vent
Function:
noun
Etymology:
Date:
15th century
The PRIMARY purpose of a plumbing vent is to equalize pressure in a plumbing system in order to protect the traps.
It's PRIMARY purpose is not to vent sewer gasses. That may happen but that is not why code requires each fixture to be vented.
22rifle is offline
Old 07-15-2008, 10:27 PM   #33
Tom R's Avatar
Thanks, - - I would never really need one myself, - - but the info you've given is great to know in case this ever comes up with a customer again.
Now it does make me curious if the guy was going to do a smoke test, - - or if he was just going to eliminate the trap either way.
Anyway, - - I will let her know that if she was ever to decide to get it done, - - to make sure they do that test . . .
Tom R is offline
House Thermostat Setting? Putty Truck HVAC 16 12-05-2007 11:29 PM
Raining in the House oldfrt General Discussion 9 11-07-2007 10:10 PM
First time house newguy07 General Discussion 11 10-01-2007 09:51 PM
The foundation for my house hishighness Construction 1 08-30-2006 07:13 AM
Installing wood in a guest house Bob H Flooring 12 12-05-2005 10:33 AM
