Trade: Residential Development
Whirlpool Service Access Panel Top Install?
I've got a situation where a RH whirlpool abuts a shower enclosure on the side where the access panel needs to be. (I would provide a picture but I don't have 15 posts and can't post links yet) The whirlpool should be a LH unit with the service access on the other side so an access panel could be inside the vanity. However, the tub was purchased AND SET by someone else. Worse yet, the tub has been drilled for the fixtures so it is not returnable.
Knowing that I can't put the access panel IN the shower because it won't be water tight and would never pass inspection, the only thing I can even think of doing is to put an access panel in the top of the decking between the whirlpool and the shower, which would both look like crap and also have to be water tight. But the homeowner is flatly refusing to purchase a LH unit. So, has anyone ever done an access panel in the top decking of the whirlpool, and if so can you make any suggestions on how to waterproof it or suggest any products that I might use to get this thing to pass inspection? |
Re: Whirlpool Service Access Panel Top Install?
what about from below?
Well, I'd have to check the joist layout to see if it was even possible but that would put the access panel in the ceiling of the kitchen above the over-counter kitchen cabinets.
Trade: Plumbing & Gas Contractor
If it sits on a outside wall it's possible to install a exterior access panel.I've done many,they're code approved if done properly.
Chief Toilet Mover
Trade: Bathroom Remodeling
Ack!
This is tiled right? Tile an access panel on the top and caulk the seam instead of grouting it. Have the homeowner take a picture of the opening so they can figure out where it is later. I have no idea if this would fly by code, so make sure on your own. |
| Service Magic's new service | Grumpy | Marketing & Sales | 12 | 08-02-2008 04:31 PM |
| You think I can install this service panel myself? | Mike Finley | Electrical | 9 | 12-25-2007 04:04 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
| Service Panel | Glasshousebltr | Electrical | 3 | 10-20-2005 05:45 PM |
| Service Panel Up To Code?? Two 120 Breakers 4 240v | Johnny916 | Electrical | 4 | 04-12-2005 02:50 AM |
