Unregistered
Guest
Posts: n/a
Where My Valves?????
I am trying to install a under counter water filter. This home is ranch, 1957. There are no water shut off valves to be seen under any sinks. WHERE ARE THE VALVES???? what is the proper way to install the filter in this case. They are copper pipes
John |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Where My Valves?????
The long and the short of it is that you don't have any.
This is the perfect time to update the plumbing and add them since you are tearing into it already. Just turn off the main water valve, disconnect however the sink feed lines are connected to the copper under the sink and add the shut offs. |
| Zone valves and transformers | mdshunk | HVAC | 3 | 05-13-2007 10:49 PM |
| What do you think about the new generation of interchangeable/upgradeable valves? | Mike Finley | Plumbing | 1 | 01-31-2007 11:56 PM |
| !!!! Thrust block your valves or ending water Stubs... | Little | Excavation & Site Work | 14 | 10-18-2006 11:18 PM |
| Backflow and Check Valves | rjordan392 | Plumbing | 7 | 08-20-2006 08:50 PM |
| Air admitance valves - why not just use them all the time instead of vents? | Mike Finley | Plumbing | 9 | 05-16-2006 08:08 AM |
