What's It Called?
Old 03-17-2009, 01:42 PM   #1
747's Avatar
What's It Called?
I was watching ask this old house about a month ago. They went to this womens house in park ridge illinois. The problem. When her subdivision would flood the water would work its way back through her sewer pipe and flood her basement. The solution. They dug to the sewer pipe in the front yard cut out a section and installed a cast iron section that has like a trap door in it. It allows water to flow out but if water tries to flow back in it cant because of that door in the cast iron pipe. It was about 4 feet long and awesome looking. I can't find any info on what that is called. Any ideals.
747 is offline
Old 03-17-2009, 02:03 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: What's It Called?
I used to live in Park Ridge before I moved to this dump (Lombard), a check valve or backflow prevention Device (BPD).
mickeyco is offline
Old 03-17-2009, 02:34 PM   #3
JonM's Avatar
Another name....sewer back flow check valve
JonM is online now
Old 03-17-2009, 02:41 PM   #4
mickeyco's Avatar
Chicanery, you just took those words from the post above and moved them around a little, didn't you.
mickeyco is offline
Old 03-17-2009, 02:46 PM   #5
JonM's Avatar
Did I step on your shoe seņor?......
JonM is online now
Old 03-17-2009, 02:49 PM   #6
mickeyco's Avatar
No, but I'm wise to you.
mickeyco is offline
Old 03-18-2009, 04:57 PM   #7
747's Avatar
I found it on the ask this old house website. Here is the company that did it.
http://www.parksplumbingandsewer.com...trol/index.htm
747 is offline
Old 03-18-2009, 05:41 PM   #8
ILPlumber's Avatar
Trade: Plumbing and Pipefitting
backwater valve.
ILPlumber is offline
Old 03-20-2009, 10:37 PM   #9
jayson22's Avatar
Trade: Plumbing & Heating
Mainline backwater valve is what I use on the main drain, but in no way is it 4' long
http://www.backwatervalve.com/
Innovative Plumbing & Heating
Calgary Plumbing & Heating Services
www.innovativeplumber.com
jayson22 is offline
Old 03-20-2009, 10:43 PM   #10
jayson22's Avatar
nice post, I didn't know about these valves until now. I guess they are designed for mobile lots and such.
jayson22 is offline
Old 03-20-2009, 10:44 PM   #11
jayson22's Avatar
I meant to quote this one
jayson22 is offline
Old 03-28-2009, 02:55 PM   #12
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Picture of a backwater valve.
Ron The Plumber is offline
Old 03-29-2009, 06:08 PM   #13
Paul B's Avatar
These are required in Balto County MD on every job where the basement is below grade
Paul B is offline
Old 03-31-2009, 02:31 AM   #14
747's Avatar
Thats the kind she originally had. It blew out because of the pressure from the flood. So they replaced it with a awesome cast iron one.
747 is offline
What is called a productive day on your site? Graham J Framing 26 04-01-2009 01:33 AM
Why is a wire nut called a bug in some places? 22rifle Electrical 9 06-29-2008 03:26 PM
Lead Service Called Every Contractor BMAN Online Leads Services 3 11-19-2007 03:49 PM
Clients today are called..... KentWhitten General Discussion 0 10-14-2007 03:35 PM
The tool repair called me after 2 years nywoodwizard Tools & Equipment 3 05-21-2007 03:37 AM
