Fortune and glory, kid.
Trade: Remodeler/Restorer
Rewards Points: 1,022
What's Best To Seal A Leak At A Soil Stack Fitting?
Is there a material that can be applied to a seam to stop a leak on a soil stack. It appears there is a leak at both the joint between the pvc and where the PVC joins the old cast iron. Maybe an epoxy of some sort?
this was obviously patched before, looks like some type of 'crete, maybe something else. Any thoughts would be appreciated.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
The Grand Wazoo
Rewards Points: 1,864
Re: What's Best To Seal A Leak At A Soil Stack Fitting?
The only correct way to fix it is to cut the plastic stack, remove it from the CI hub and repour a new adpt into the hub and reconnect it to the existing plastic.
The Following User Says Thank You to KillerToiletSpider For This Useful Post: |
moorewarner (01-17-2011)
3 T,s plumbing
Trade: plumbing and heating
Rewards Points: 25
cut the bad pvc fitting out--cut(or snap if its not to dangerous of a spot) that hub off--fernco connect back together
The Following User Says Thank You to 3 T,s Plumbing For This Useful Post: |
moorewarner (01-26-2011)
The Grand Wazoo
That would be a code violation here.
3 T,s plumbing
Rewards Points: 25
using a fernco is a code violation in ill.? we have pretty strict codes in mi. but you can use ferncos here.
The Grand Wazoo
They can only be used underground, they are not a rodent proof connection.
3 T,s plumbing
Rewards Points: 25
what code do you use in ill.? always like to ask-seems we all have different rules and codes all over.
The Grand Wazoo
Most of the state uses IL code as written by Dean Thaedy, in Chicago we use a lot stricter code.
Trade: Commercial Electrician
Rewards Points: 83
You're allowed to use a mission band though correct? I got busted by a home inspector when I sold my house because I used Fernco's instead of Mission bands to go from Cast to PVC. The buyers got a quote for $500 to fix 5 bands. Took me $25 and an hour to fix it.
The Grand Wazoo
Re: What's Best To Seal A Leak At A Soil Stack Fitting?Nope. Lead and oakum. I am here to pound the lead.
Rewards Points: 83
Re: What's Best To Seal A Leak At A Soil Stack Fitting? |
Trade: ooo
Rewards Points: 2,000
Holy crikes
![]() If your a homeowner and you don't have lead tools then just take screwdrivers and peel the caulked joint out. Grab a radio and a five gallon bucket to sit on and have fun with it. Once it's all clear try and clean it up a little. Then go to a hardware store and get some oakum. Take the joint and start laying it in. Take some screwdrivers and start packing the joint tight working it around in circles making it even and working it in the whole time. Ok, now get some Pro-poxy (looks like clay) and roll it long and lay it on top of the bed of oakum. Then take a 1/4" wood dowel or whatever you have and start driving it home. As it begins to set it's going to get hard, at this point you have to really hammer it down tight. Your done and it's work great. Lead joints are great but if your not a plumber lead doesn't make sense. As far as cutting the cast iron; Why? Why would you cut something that is perfectly fine? The joint is bad not the material. Also, that looks like a fitting that's sticking up through the floor.....NEVER cut, crack, bust, or grind on a fitting coming out of a floor. If you do what I explained you wont have problems. ![]() Mike
see ya!
The Following User Says Thank You to Mike's Plumbing For This Useful Post: |
moorewarner (04-26-2011)
Trade: Construction
Rewards Points: 2,394
Re: What's Best To Seal A Leak At A Soil Stack Fitting?![]() ![]()
www.bcconstructionllc.com |
Trade: ooo
Yes
![]() ![]() Mike
see ya!
Trade: ooo
see ya!
BCConstruction (01-27-2011)
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Back in the early 70s (3 or 4) I was working gas and water pipe crew here in Richmond and we would pour lead for water mains..... You Really want to make sure it's dry and you have eye protection...
Pounding lead... Takes me back. |
Thanks for the responses gents, here is the finished product.
The adapter was was affixed with okum and a bonding/sealant recommended by the plumbing supply house; okum>bead of sealant>okum>sealant>okum>sealant>etc.. I am going to try out the new project feature and detail al the work that got done here. Nice upgrade CT. ![]()
#18 |
Re: What's Best To Seal A Leak At A Soil Stack Fitting?Advertisement
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Under slab leak?? | 220/221 | Plumbing | 9 | 03-20-2010 11:45 AM |
Refrigerant Leak Detection Articles | MechAcc | HVAC | 7 | 10-09-2009 04:42 AM |
Epdm Lap Seal | thorroofer | Roofing | 13 | 09-21-2009 11:47 PM |
Stoping rain leak issues on vent stack with 2 90's? | Security101 | Plumbing | 17 | 03-10-2009 12:05 PM |
Go to Page... |
