What Kind Of Sealer?
Old 11-14-2009, 04:41 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
My friend who's a plumber told me to use this
Any others that are reliable? or dis-reliable?
KennMacMoragh is offline
Old 11-14-2009, 06:53 PM   #2
ILPlumber's Avatar
Trade: Plumbing and Pipefitting
Re: What Kind Of Sealer?
Keytite
ILPlumber is offline
Old 11-14-2009, 09:45 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Megaloc
Ron The Plumber is offline
Old 11-14-2009, 10:38 PM   #4
Moderator
Double-A's Avatar
What are you using it on? On everything I use RectorSeal T+2. On black gas I will use RectorSeal #5.
I have used MegaLoc but I'm unimpressed. Its messy, doesn't wash out of your clothes and if the batch isn't a good batch, it will harden and become a thread locker. I've never used Keytite.
That TruBlue you're showing is a vibration resistant sealant. Not required for most applications.
New York Times, July 20, 2006
Double-A is offline
Old 11-15-2009, 02:21 AM   #5
^^ Nothing in particular, just wanted some to keep with me for doing handyman work. I put in some pvc pipe in my dads basement for a water line a while back, I started out using a cheap joint compound, I don't remember what it was, but it was the only thing they had at the store. It was really runny, so I put it all together and it leaked. I went to a different store and bought another kind, this stuff was thicker, it looked like a better compound, but I put everything back together and it still leaked. I still haven't fixed it, it's still leaking now but it's a real minor drip.
I asked my friend about it, he said if it's pvc I need to use both teflon tape and a sealant. He said use Tru Blu with the tape and it won't leak. I don't know why he told me Tru Blu though.
I thought all sealants were the same, obviously they're not, but I'd like to keep a decent kind with me just for doing odd jobs. I read about all the ones mentioned here. Seems like the Megaloc is the strongest, but if it locks the threads so you can never get it off, that would not be good. Maybe since you both mentioned Rectorseal, the T plus 2 would be the best one.
Old 11-16-2009, 09:50 AM   #6
wookie's Avatar
Trade: plumbing
Laco slic-tite on water along with teflon tape when needed, Keytite on gas works for me.
wookie
wookie is online now
Will using a sealer on air entrained concrete reduce the benefit? jgray152 Masonry 1 10-04-2009 09:29 AM
aluminum roofing sealer J CORRIN Roofing 1 07-26-2009 12:24 PM
Need advice on sealer problem. concreteartist1 Specialty Coatings 3 07-15-2009 06:03 PM
clear sealer over acid stain Traditions2 Painting & Finish Work 7 12-09-2008 09:46 PM
sanding sealer on windows ? sprayer48 Painting & Finish Work 8 10-24-2008 12:10 AM
