What Can I Sue To Solder Brass To Brass
Old 10-05-2005, 11:14 PM   #1
izote61's Avatar
Trade: house remodeling
i need to solder brass to brass, there is special soldering material that i need to use? i always solder copper pipes, please advise me in this one. always thank you.
izote61 is offline
Old 10-05-2005, 11:27 PM   #2
plumguy's Avatar
Trade: plumbing and heating
Re: What Can I Sue To Solder Brass To Brass
I don't use anything special! Usually when I'm doing it...it is brass to copper (ream(sp) adapter) and I use the same flux,solder,etc.
plumguy is offline
Old 10-05-2005, 11:35 PM   #3
Teetorbilt's Avatar
Low temp silver solder is the best, lead will work too.
Albert Einstein
Teetorbilt is offline
Old 10-06-2005, 12:24 AM   #4
plumguy's Avatar
Originally Posted by Teetorbilt
lead will work too.
Not on potable water lines!! Or at least around here!
plumguy is offline
Old 10-06-2005, 10:04 AM   #5
Teetorbilt's Avatar
Sorry, I'm old and still refer to plumbing solder as 'lead' because it used to be and that is what we called it.
Albert Einstein
Old 10-06-2005, 05:06 PM   #6
Tom R's Avatar
LOL, - - you ain't that damn old, - - or maybe I say that cuz I'm only about 5 years behind you, - - I don't think you even qualify as a 'codger' YET!!
http://www.tr-built.com
Tom R is offline
Failed Solder in drainlines Pearce Services Plumbing 4 05-06-2007 10:11 PM
I goofed- how do I remove solder from wall panels? Dustball Plumbing 12 05-04-2007 10:40 AM
Brass or Galv Nipple Stubs? Ron The Plumber Plumbing 5 02-02-2007 06:33 PM
Cheaper source for good brass knife hinges ? karma_carpentry Finish Carpentry 3 12-17-2005 10:15 AM
Brass shower drain extender dtnflyrfan Plumbing 1 04-15-2005 03:49 PM
