Trade: HVAC
What 2 Use 4 Water Line To House?
copper or PVC? The house has all copper in it..new construction..3/4 lines?
i have 65 feet to reach inside house..1 in copper is like 5.00 a ft & 3/4 is like 4.00 a ft PVC is .34 a ft but what are the pros & cons? weve never had a problem in old house with copper..moved to a temperary house (after selling ours) with cpvc & PVC main water line & now wife gets bladder infections all the time..just coincendence or is there something to it..most places sale 60 or 100ft soft copper only..so is 4-5 a ft for 100ft woth it i guess or not? also would 3/4 from water meter be suffient enought to do the house with 3/4 throughout it now or do i need to adapt up to 1 inch? |
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: What 2 Use 4 Water Line To House?
If it was my house I would put in 1'' copper but, most people use poly pipe for water service, I just don't like it.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Trade: master plumber/owner
Copper is so yesterday for yard services. If you leave the ditch open for inspection you'll come back to an empty ditch. I got tired of copper getting ripped off. Pex is what most people use now. It's easy and the cost is low.
Trade: Squirrel Handler
Re: What 2 Use 4 Water Line To House?![]() L ![]()
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Go copper, it's been proven for a century. Today the major cost is digging the trench.
David Davis
Trade: ? No thanks, I like mine better!
I am no plumber, but from what I understand(and I don't really understand much), it is against code to have 3/4" plumbing except from hook up to hot water heater....The rest, as I have been told, is required to be 1/2"......Maybe it's a local thing, I don't know...
My unknowledgeable preference would be copper...I have worked with copper, and cpvc, and I have to say...I would rather burn myself working with copper, than to run cpvc....I don't know the difference, not even if there is one...But copper sure is a lot prettier....
Shed |
Plumber / Carpenter
Me? in VA I always use 180 psi black plastic pipe, comes in a roll, just roll it out, no leaks, never rots, never had any troubles
Pro Plumber
Trade: Plumber
Go Pex 1" you won't have to worry about pin hole leaks a few years down the line.
It might be "so yesterday" but it will see many more tomorrows than plastic will. I am in a house 20 years old right now that has a leaking in the poly water service. Wouldn't be leaking after 20 with copper and I wouldn't be cutting up my kitchen floor to run a new line in, copper can be fixed, plastic needs to go end to end. Plastic pipe for potable water is cheap, it was made popular because it's cheap, by plumbers that don't care about being the best.
LRG WoodCrafting
Very likely there is something to it. Copper has antibacterial properties. Copper is toxic to a lot of bacteria. The plastic has no such abilities.
#11 | |
The Grand Wazoo
Re: What 2 Use 4 Water Line To House?Quote:
Pro Plumber
Trade: Plumber
#13 | |
#14 | |
i run pools on copper & zink, w/ less chlorine than drinking water. romans kept copper & silver slugs in H20 barrels, to curb bacteria ray
......Less with the jaw & More with the paw..... |
#15 | |
Don't get me wrong, I'm not questioning the quality of copper, but if there is a more cost effective product that holds up just as well then I'm all for it. Every pipe has its pros and cons, and it boils down to personal preference. I prefer pex, and my next choice would be copper. I never use cpvc or pvc for water though because it just feels unprofessional to me.
| Removing iron from water | Michaeljp86 | Plumbing | 3 | 09-05-2007 09:25 PM |
| Grading problem and solution needed, water can't escape... | Little | Excavation & Site Work | 12 | 05-15-2007 03:45 PM |
| Water heater Help | tzzzz216 | Plumbing | 10 | 11-22-2006 03:30 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| Funding for first spec house? | ruskent | Business | 28 | 01-17-2006 08:10 PM |
