Weird Anti Freeze
Old 10-05-2009, 09:53 PM   #1
mics_54's Avatar
Trade: contractor
Weird Anti Freeze
Yesterday I winterized a house. I had several jugs of RV anti freeze that I introduced into p-traps and when I poured it into the toilets I noticed the pink anti freeze turned bright yellow. I noticed today it was clear again. whiskey tango foxtrot! Ever seen this before? Its artesian well. The house next door on the same well didn't do it. There is no water softener..I didnt see any tank bowl tablets. I'm baffled.
mics_54 is offline
Old 10-05-2009, 10:26 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Weird Anti Freeze
Get out the anti freeze tester, like they use on a car, see if it test ok.
Ron The Plumber is offline
Old 10-05-2009, 10:33 PM   #3
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
If there is bleach in the toilet it will change the color of the antifreeze as you say. Usually bleach was used to clean toilets and if any is left this is what will happen. Even those toilet bowl cakes.
XanadooLTD is offline
Old 10-05-2009, 10:34 PM   #4
XanadooLTD's Avatar
It definitely turns it clear.
The Following User Says Thank You to XanadooLTD For This Useful Post:
mics_54 (10-05-2009)
Old 10-05-2009, 10:46 PM   #5
mics_54's Avatar
Trade: contractor
Thanks...that makes sense since the house was vacated and prepped for sale. I was scratchin my head wondering what the heck I poured into the toilet second guessing my self after I get home..I always do that.
mics_54 is offline
Old 10-06-2009, 01:24 AM   #6
mics_54's Avatar
Trade: contractor
Next question is, will the bleach make the glycol ineffectual? Do I need to go flush it out and reintroduce the glycol?
mics_54 is offline
Old 10-06-2009, 09:47 AM   #7
XanadooLTD's Avatar
I don't know the actual answer, but i do flush the toilet to remove the bleach again just to be on the safe side. Then ya reintroduce the propylene glycol. hope this helps.
mics_54 (10-06-2009)
Old 10-06-2009, 10:16 AM   #8
This sounds like good advice.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Old 10-06-2009, 06:37 PM   #9
gregj's Avatar
I think the color change means someone's pregnant! LOL
The bleach is bleaching the dye that was added to the antifreeze just for pretty. Propylene glycol is colorless. Household bleach diluted in a toilet bowl won't affect the freeze resistance of the glycol. It's ok.
gregj is offline
The Following 2 Users Say Thank You to gregj For This Useful Post:
mics_54 (10-06-2009), XanadooLTD (10-06-2009)
Old 10-08-2009, 12:29 AM   #10
Sluggin away
FremontREO's Avatar
Trade: Dihydrogen monoxide remediation/GC/REO/Insurance
A word of advice or help?
If you are doing the winterize for property preservation companies a little trick that the "old timers" will do so YOU will not be paid or so somebody else can come and "rewinterize" and you get chargebacked for your work or non-paid:::::
here goes: put denture-cream or some toothpastes in the toilet. Magic the RV Antifreeze loses its color...
Good luck protecting yourself.
FremontREO is offline
The Following User Says Thank You to FremontREO For This Useful Post:
mics_54 (10-08-2009)
Repairing freeze damaged plumbing -whole house. matt832 Plumbing 5 08-09-2009 03:23 PM
225 De-motivational posters - sorta anti CDat-ish wallmaxx Off Topic (Non Trade) 26 12-01-2008 04:06 PM
Wet saw anti freeze EASTSIDE Ceramic & Stone Tile 5 11-21-2008 06:26 AM
Weird gran_national Sandblasting 4 10-30-2008 07:49 PM
Having a weird popup KentWhitten Site Help and Suggestions 26 09-23-2008 09:11 PM
