Weekend Plumbing Surprise - Plumbing - Contractor Talk
Old 02-03-2018, 11:59 AM   #1
Lettusbee's Avatar
Rewards Points: 2,740
So, my P-trap tubular fell off the kitchen sink just now. Breaking it apart to clean it up and it looks like someone used pipe dope on the threads?
I thought these weren't supposed to get anything at all, but I do know a couple of plumbers that like to use a little bit of silicone on the threads.
I'm going to patch this together for the weekend, and call a real plumber on Monday, but just wondered what the general opinion was for sealing the threads on tubular?
Lettusbee is offline
Old 02-03-2018, 01:26 PM   #2
rrk's Avatar
Rewards Points: 2,316
Re: Weekend Plumbing Surprise
Just put the pipe dope on the beveled washer or on the bevel of the U , no need for it on the threads
rrk is online now
Old 02-03-2018, 01:34 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,515
I think some guys do it so they don't shake loose over time, which they often do, esp. with a garbage disposer.
That's a wild set-up.
MarkJames is offline
Lettusbee (02-03-2018)
Old 02-03-2018, 02:17 PM   #4
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
If that works, it does show that water does run up hill!
Dave in Pa is offline
The Following 3 Users Say Thank You to Dave in Pa For This Useful Post:
Lettusbee (02-03-2018), SmallTownGuy (02-03-2018), tang (03-15-2018)
Old 02-03-2018, 03:44 PM   #5
tgeb's Avatar
Rewards Points: 1,254
That is about the most Dr. Seuss looking P trap I have ever seen....And I've seen some things...
www.gebcon.com
tgeb is offline
The Following 7 Users Say Thank You to tgeb For This Useful Post:
dayexco (04-15-2018), Fouthgeneration (02-05-2018), Inner10 (02-05-2018), Jaws (04-15-2018), Lettusbee (02-03-2018), RickP (02-05-2018), tang (03-15-2018)
Old 02-03-2018, 04:50 PM   #6
Renaissance Man
superseal's Avatar
Rewards Points: 5,474
That's not even close to a legal trap arm...and no pipe dope necessary
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Irishslave (02-04-2018), Seven-Delta-FortyOne (02-03-2018)
Old 02-03-2018, 04:53 PM   #7
Renaissance Man
superseal's Avatar
and it's gotta be one smelly azz sink
The Following User Says Thank You to superseal For This Useful Post:
rrk (02-03-2018)
Old 02-03-2018, 05:16 PM   #8
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 450
That looks like one of those projects the plumber is like... how will I connect this?? 🤔 here maybe this will work.... maybe this... let's get done so we can leave.... whistling
Jonbuild is offline
Old 02-03-2018, 05:19 PM   #9
MarkJames's Avatar
Originally Posted by Jonbuild View Post
That looks like one of those projects the plumber is like... how will I connect this?? �� here maybe this will work.... maybe this... let's get done so we can leave.... whistling
Old 02-03-2018, 05:20 PM   #10
MarkJames's Avatar
100% homeowner job...parts bought on a crowded Saturday morning at HD with kids in tow.
A&E Exteriors (02-04-2018)
Old 02-03-2018, 05:32 PM   #11
Lettusbee's Avatar
You should see some of the rest of the house.
It has worked well enough over the last four years that I had never given it a second glance. I'm definitely not a plumber though.
It's patched up for now, will be getting my plumber on it next week.
BTW, love the Dr. Seuss comment. I usually refer to these things as Fisher Price, but will keep Dr Seuss in mind.
The Following User Says Thank You to Lettusbee For This Useful Post:
tgeb (02-04-2018)
Old 02-03-2018, 07:02 PM   #12
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 44
Why was this a
>>> "SURPRISE" <<< ???
I'm not a plumber, but the first time I looked under the sink I'd be EXPECTING to redo this sometime in the near future.
P42003 is offline
Old 02-03-2018, 07:22 PM   #13
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,576
The funny thing is it appears all that nonsense isn't even needed. Shorted the stem from the strainer. No pipe dope, but often the plastic nuts need to get re-tightened every once and a while.
Golden view is online now
Old 02-03-2018, 07:27 PM   #14
VinylHanger's Avatar
Rewards Points: 8,026
Mine was held up by a coat hanger when we moved in. I figured hack, it's held this long, why worry about it.
It decided to five way after I filled both sinks with funky nasty waste water while cleaning.
Of course, I just retied it with a new coat hanger for a while until I fixed it.
That worked great until I dumped a pot of old leftover soup in the sink.
I did fix it that time.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 02-03-2018, 08:37 PM   #15
Lettusbee's Avatar
Originally Posted by P42003 View Post
Why was this a >>> "SURPRISE" <<< ???
I'm obviously not a plumber either, and I knew it didn't look like the pictures in any plumbing book I've ever seen. But I didn't know it was that bad.
After all it worked for the most part, for the past 4 years.
Texted the pic to my plumber and his response was "That's a mess man"
Old 02-03-2018, 09:33 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,431
I have stuff in my house that wasn't done to code when we moved in 32 years ago, and it's still working just fine. Go figure.
Tinstaafl is offline
Old 02-03-2018, 10:15 PM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 436
Uh, whoever did that piping is an idiot.
It flows uphill after the trap. No reason for that at all. The tailpieces are just too long. What a fvkk up.
And no, you don't pipe dope PVC threads, as a general rule.* Certainly not a trap arm with a washer in it.
*Yes Killer, I know there might be time when you would, like attaching a threaded Schedule 80 nipple into a galvanized or brass female fitting. That's why I said, "in general". Still, I'll tape the male, and dope the female.
Delta
I have an Edifice Complex.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Fouthgeneration (02-05-2018), Irishslave (02-04-2018)
Old 02-04-2018, 06:44 AM   #18
rrk's Avatar
If it was a bowl and a half sink the tails are the right length the wall outlet is too high. I can't see the 2nd bowl. I am assuming the one I can see is the shorter bowl.
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
MarkJames (02-04-2018), Seven-Delta-FortyOne (02-05-2018)
Old 02-04-2018, 07:41 AM   #19
MarkJames's Avatar
If only they made disposers with a higher drain outlet..even a half inch or so would be cool. Know what I mean?
Old 02-04-2018, 10:21 AM   #20
Lettusbee's Avatar
It's a full two bowler. The pics are showing the whole contraption where it fell about an inch. A coat hanger to hold it up would likely be a perfect long term solution
Every single kitchen and bath I've remodeled we've had to lower the drain outlet.
On this one, I'll open up the wall from the outside and rework the drain height. I've been replacing my siding this winter and have had to replace a lot of the Osb sheathing by the Windows anyway. The house was tyveked in spots only,and where there is housewrap, it's not correct.
What states require plumbing diagram for residential? ScipioAfricanus Architecture & Design 8 08-09-2013 06:52 AM
Not how I'd planned to spend my weekend. I hate plumbing. pinwheel Plumbing 2 07-30-2013 09:22 PM
July 4th weekend Kent Whitten Off Topic (Non Trade) 21 06-30-2013 06:10 PM
plumbing and electrical permits johnisimpson General Discussion 13 12-09-2008 07:06 PM
Kitec is history. So is Rehau PEX Plumbing. 22rifle Plumbing 0 11-14-2008 03:30 PM
