Waterline Tapping
Old 02-07-2007, 10:30 AM   #1
mastadon's Avatar
Trade: Commercial Plumbing Maint.
Waterline Tapping
Has anyone ever tapped an 8" steel waterline for a branch run?
mastadon is offline
Old 02-07-2007, 10:56 AM   #2
dayexco's Avatar
Re: Waterline Tapping
steel? this inside of a building, or buried outside? you're not talking about cast iron, ductile iron pipe, are you? i would think your supplier should be able to get you a tapping saddle/corporation valve for that pipe if it's IPS sized. you will have to borrow/rent/buy the tapping tool. it's not difficult at all
dayexco is online now
Old 02-08-2007, 07:55 AM   #3
mastadon's Avatar
This is for a fire sprinkler system and it is in the ceiling. Thanks for the info.
If it wasn't for your plumber, you wouldn't have any place to go!!
mastadon is offline
Old 02-08-2007, 08:14 AM   #4
Professional Remodeler
firemike's Avatar
What size branch do you have to install? If you can shut it down and drain it you could hole saw it and use a saddle style tap.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 02-08-2007, 09:46 AM   #5
dayexco's Avatar
if the pipe is IPS, you should be able to get a tapping saddle and corporation valve and do it hot
Tapping noise ... RobertWilber Electrical 3 09-07-2006 07:22 PM
