Water Softner Question?
Old 05-19-2006, 11:45 AM   #1
CC1's Avatar
Trade: Utilities Supervisor
Can someone explain to me why my brine readings are at 50 and 43 on my two brine tanks? I have never seen them this low. My co-workers added salt to the brine pit the last two days, but the level has not risen. A normal reading for us is between 85-93.
I understand the basic concept of a water softner system, and this tells me that for some reason the water and salt are not mixing in the brine tank. What should/can be done?
CC1 is offline
Old 05-19-2006, 05:15 PM   #2
workman's Avatar
Trade: general contractor
Re: Water Softner Question?
What kind of salt (brand) are you using? How are you checking the brine level?
workman is offline
Old 05-19-2006, 05:53 PM   #3
CC1's Avatar
I'm in Japan, so I use a Japanese vendor for the salt. How do I check the brine level? I use a salometer to take readings in the brine tanks.
This is a commercial setup, not residential. Probably should have said that before. I'm using 3 Kisco Triple DV 3660-2 1/2's
There is plenty of salt in the brine pit and plenty of water, about 1/2 full of water right now.
After looking at the past few days usage (I've been off) it seems that our soft water useage has doupled for the past 4 days. I can only conclude that the softners have been cycling so much that the water refilling the brine tank hasn't had enough time for absorbtion.
Any other thoughts?
CC1 is offline
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
water softner kage06 Plumbing 0 06-06-2006 06:54 AM
Question for the Plumbers , water closets tzzzz216 Plumbing 3 03-19-2006 01:28 AM
Hot water question RobertCDF Plumbing 23 01-25-2006 07:54 PM
