Water Pressure Problem
Old 02-24-2008, 05:14 PM   #1
OraarO's Avatar
Hi all plumbers -
In my home, the water pressure (cold) is good at all faucets, washer, etc. The hot water is fine only coming out of the basement laundry faucet.
What might be the problem?
We have no water softner, a fairly new (5 - 10 year old) water heater.
One concern is their is a rust color buildup that comes out of the faucets if we have not used for several days, and a yellow buildup on aereators (sp?) that needs to be rinsed off maybe once a year.
Is this maybe blockage in the pipes? Any thoughts?
Thanks,
OraarO is offline
Old 02-24-2008, 06:03 PM   #2
Teetorbilt's Avatar
Re: Water Pressure Problem
The rust color is probably coming from old galvanized pipes that are somewhere in your system. It's most common in the run from the meter/well to the house.
Your thoughts about a blockage on the hot side parallel mine. A chunk of scale could have easily come loose at some point and only recently flipped over to block your supply of hot.
Albert Einstein
Teetorbilt is offline
Old 02-24-2008, 06:41 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
I think it's time for you to repipe with pex piping.
Ron The Plumber is offline
Old 02-24-2008, 06:53 PM   #4
Teetorbilt's Avatar
Like a repipe is cheap! If I'm going plastic, I'm going PU and not PE. I'm also going SS Cammozzi, not cheap.
Albert Einstein
Old 02-24-2008, 07:34 PM   #5
masterk's Avatar
Trade: Plumbing
Years back there was a problem with the dip tube breaking up. Turn off the water to your house, remove the stem to one of the hot supply angle stops. If it has small pieces of plastic in it then thats it. You will have to do every fixture like this, maybe more than once.
masterk is offline
Old 02-28-2008, 07:16 PM   #6
roullette's Avatar
Trade: Plumbing heating and A/C
well my personal opinion would be to put a pressure gauge on the draw off at the water meter (if there is one) or on a silcock to get a good reading of what your pressure is at.
also do you have a 2nd floor? house old? what size is your water main?
if you flush a toilet does your water pressure drop alot at your bathroom faucet?
could be a pipe sizing issue or like someone just posted if you have an old house with galvi pipe they could be rusting out and/or full of sediment.
roullette is offline
water heater problem remodeling joe Plumbing 4 01-30-2008 12:27 AM
Water heater problem redbird Electrical 3 03-29-2007 07:50 PM
Drainage Question Murphy Excavation & Site Work 19 01-01-2007 04:19 PM
water pressure with on demand heaters Vermonster Plumbing 2 11-11-2006 07:14 AM
interesting problem! thunder7 Plumbing 7 02-04-2006 10:26 PM
