Water Pressure
Old 01-09-2004, 09:14 AM   #1
dave's Avatar
Water Pressure
I recently purchased a home with a well. The psi on the pump reads 40psi which I was told is about right.But if I turn water on down stairs the water pressure upstairs is very poor.Is there anything I can do to increase my water pressure?
dave is offline
Old 01-09-2004, 02:01 PM   #2
General Contractor
hatchet's Avatar
Re: Water Pressure
Probably the most drastic would be to increase the diameter of the incoming piping from the well.. although this may have consquences with your pump size.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 01-15-2004, 09:13 PM   #3
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Re: Water Pressure
Increasing the line size will on allow more volumn not pressure. 40psi is low for pressure. I would boost the pressure switch to about 55-60psi so that when in use the pump will kick on sooner not allowing the pressure to drop too low.
advice on low pressure well problem 72chevy4x4 Plumbing 0 07-16-2007 07:54 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
water pressure with on demand heaters Vermonster Plumbing 2 11-11-2006 07:14 AM
Water cooled units tripping on high pressure rookietech2006 HVAC 3 08-06-2006 08:56 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
