Water Leak Sensor For Vacation Rental
Old 09-10-2017, 02:07 PM   #1
Sammy_242's Avatar
Trade: General
Rewards Points: 12
I am managing a few vacation rentals and want to monitor them without much effort. I have local resources to help out if needed, but trying to minimize calling on them. There is wifi router shared between the two properties on the same lot.
Has anyone used a water leak sensor to monitor for plumbing damage? If so, what has been your experience? There are a few obvious places to put them, such as near the hot water pump, faucets, and toilets but I'm not sure the pros/cons.
I also found a system that detects drain blockage that could be useful for preventative maintenance, but haven't found many people using it.
Sammy_242 is offline
Old 09-10-2017, 10:53 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,738
Re: Water Leak Sensor For Vacation Rental
Yup.
I bought this last year to set on the floor next to my oil fired boiler for heat and hot water.
The copper springs pin-hole leaks and if I don't go down in the basement for a day, I've got a real mess.
Simple to set up and extremely sensitive.
It comes with phone cable of I think 12' but you can increase that to whatever length you need. A 18" sensor connects to the phone cable and is placed wherever you need it.
To test it, I just touched my finger to my tongue and then touched the sensor and the notification on my phone was instant.
You can hook up as many as needed...just name them different names.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Robie is online now
Old 09-11-2017, 07:38 AM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,602
I use the GRI ones and connect them to an alarm system. I've also used Water Bug and Lyric.
Inner10 is offline
Old 09-11-2017, 06:51 PM   #4
Sammy_242's Avatar
Trade: General
Rewards Points: 12
Originally Posted by Robie View Post
Yup.
Thanks! That looks pretty helpful. I'm probably grab a handful for all of the pluming "hot spots".
Are these sensors pretty dependable? Will they last 12-24 months or will I need to replace regularly? The internet is usually pretty good so I shouldn't have to worry about it going down too much.
Old 09-12-2017, 12:13 AM   #5
Robie's Avatar
I don't think there is anything to wear out so as long as you have a wifi connection in the location, it should last a long time.
Robie is online now
Old 09-12-2017, 09:44 AM   #6
climb's Avatar
Trade: Cabinetmaker / Finish Carpenter
Rewards Points: 44
I use Lyric in my rental. I haven't had it go off other than manually testing it. It appears to always be connected when I log on to it (unlike my thermostats). It tell me the temperature and humidity, so I have to assume it is working. I'd buy another.
climb is offline
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 07:17 PM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 08:51 PM
Water Heater Fail Dr Heat HVAC 8 11-28-2012 04:53 AM
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 07:02 PM
Moling in a new water main at a small office building Cuda Plumbing 0 10-15-2012 06:50 PM
