Water Heater Problem
Old 01-28-2008, 09:17 PM   #1
remodeling joe's Avatar
Trade: residential remodeling
my water heater won't stay hot for long anymore like it used to. a couple of glorious hot water minutes then cold as hillary's a--!! i'm thinking the elements or the thermostat....... any help would be appreciated.
thanks
remodeling joe is offline
Old 01-28-2008, 10:27 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Water Heater Problem
Dip Tube
Ron The Plumber is offline
Old 01-29-2008, 12:40 AM   #3
can you please explain in some detail...... i thank you for your reply
Old 01-29-2008, 12:51 AM   #4
Plumber
gmp's Avatar
Trade: Plumbing
He's saying the diptube may be shot.
Instead of getting the cold water to the bottom of the water it is mixing with the hot at the top.
The diptube's purpose is to keep the cold water from immediately leaving the water heater once it enters. The diptube is located on the cold inlet. It is usually plastic and inserted below the cold nipple.
How old is the water heater? There were defects in water heater diptubes in the late 90's I believe.
gmp is offline
Old 01-30-2008, 12:27 AM   #5
well guys........i checked the dip tube and it was in good shape. no cracks or breakage. i did find that the bottom element was bad, so i replaced it and hot water is on again!! thanks guys for all the advice.
Options for water heater? Tonkadad Plumbing 7 01-02-2008 01:30 PM
Grading problem and solution needed, water can't escape... Little Excavation & Site Work 12 05-15-2007 03:45 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
