Water Heater Pilot Still Wont Light.
Old 04-05-2007, 06:05 PM   #1
johnjamesalaska's Avatar
Trade: Hanger taper finisher painter
Hello all,
My pilot light went out so of course I tried to relight it. Flame comes on but it wont stay lit. SoOo I changed my thermo coupler with no change. SoOo I shut the water off and I drained my tank (I thought), by hooking up to the hose connection. It drained with decent flow for a couple of hours. There was a small bit coming still coming out but it was a very small trickle. When I pulled the thermostat off, it made a glug glug sound and water came out sOoo I quickly threw the new one in and now it wont even flame. Its a whirlpool. All the replacement parts are identical. What besides buying a whirlpool two years ago and not getting proffessional to repair it , did I do wrong?
Thanks for any help.
johnjamesalaska is offline
Old 04-05-2007, 06:17 PM   #2
mdshunk's Avatar
Re: Water Heater Pilot Still Wont Light.
Don't suppose the tank is dripping on the pilot assembly, is it?
mdshunk is offline
Old 04-05-2007, 08:22 PM   #3
nope..dry as a bone.
Old 04-05-2007, 08:33 PM   #4
Ishmael's Avatar
Trade: Plumbing
Something obstructing the exhaust vent terminal?
Ishmael is offline
Old 04-05-2007, 08:59 PM   #5
Well.. I m not sure of what an exhaust vent terminal is, but , if its that pipe coming out of the top it seems fine.
Old 04-05-2007, 09:17 PM   #6
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Thermstat controller going bad? Maybe
Ron The Plumber is offline
Old 04-05-2007, 11:07 PM   #7
JamesNLA's Avatar
Trade: Plumbing & Electrical
pipe dope get in the way?
JamesNLA is offline
Old 04-06-2007, 12:06 AM   #8
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Common mistakes, rember I have never changed a thermocouple in a water heater, just commercial gas stoves. These are in no particular order
1. using pipe dope on threads that screw into the safety valve
2. kinking the capillary tube
3. Need 1/3 of the end of the tube in the flame.
4. end of tube glowing red, indicates tube too close to flame.
5. bad safety valve.
6. plugged gas tube or pilot
7. Bad connection between nut and safte valve. Loosen and tighten again.
fireguy
fireguy is offline
Old 04-06-2007, 01:22 PM   #9
POOLMANinCT's Avatar
check continuity of safety harness? limits etc?
a redundant high limit is part of pilot circuit on some models
POOLMANinCT is offline
Old 04-06-2007, 09:17 PM   #10
Plumber
gmp's Avatar
Trade: Plumbing
Is pilot flame blue and strong? Is the flame impinging on the tip of the thermocouple about 3/8 of an inch?
gmp is offline
Old 04-07-2007, 04:09 PM   #11
call a guy
......Less with the jaw & More with the paw.....
Old 04-16-2007, 11:45 PM   #12
Terrence's Avatar
Trade: painting and carpentry
This might seem like "DUH" advice, but...
Turn the controller knob to the off position
Wait 5 minutes, and smell around for gas
Turn the controller to the pilot position
Get your match ready
Hold the controller in the down position, and light the flame
COMTINUE to hold the controller knob/button down while you count out 75 seconds and release...
Hope it helps..
g'luck
Terrence is offline
Gas water heater with timer on it? rhinoguy Plumbing 1 06-10-2010 11:11 AM
GAS WATER HEATER - pilot always going out. jman116 Plumbing 2 04-20-2007 01:22 PM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
