Water Heater Expansion Tank
Old 11-03-2009, 04:58 PM   #1
HomerJ's Avatar
Trade: Remodeling Specialist - General Contractor
Is it necessary for a new GE 50 gal 12 yr tank?
HomerJ is offline
Old 11-03-2009, 05:05 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Water Heater Expansion Tank
What does your local code specify?
KillerToiletSpider is offline
Old 11-03-2009, 08:41 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
What are you asking? Please rephrase it so it is understandable.
Ron The Plumber is offline
Old 11-03-2009, 08:47 PM   #4
Pro Plumber
Trade: Plumber
Never mind my question see KTS's response.
Old 11-03-2009, 08:47 PM   #5
solar guy
naptown CR's Avatar
Trade: solar contracting
What part didn't you understand?
He is asking if an expansion tank is required for an brand new 50 gallon Ge water heater with a 12 year warranty.
The answer depends on the local code.
If on a water system there is no backflow preventer it is not required unless by code or to satisify the warranty.
naptown CR is offline
Old 11-03-2009, 08:49 PM   #6
Pro Plumber
Trade: Plumber
Thanks I figured it out.
Old 11-03-2009, 08:50 PM   #7
Pro Plumber
Trade: Plumber
What is the residual and static pressure at?
Old 11-05-2009, 12:12 AM   #8
HomerJ's Avatar
I'll have to check the local code.
According to the plumber, there is a backflow preventer.
HomerJ is offline
Old 12-17-2009, 12:29 PM   #9
vinpadalino's Avatar
Trade: HVAC and plumbing.
If you have a well I would say no. If you have city water I would say yes to be on the safe side. depends on the psi coming from the street side though.
vinpadalino is offline
Old 12-17-2009, 06:17 PM   #10
The Grand Wazoo
No, not really.
In fact you are completely wrong.
Old 12-17-2009, 06:22 PM   #11
solar guy
naptown CR's Avatar
Please explain/\
Old 12-17-2009, 06:59 PM   #12
Originally Posted by KillerToiletSpider View Post
No, not really.
No I'm right. If you have a well tank the water will expand inside of the bladder. If you have a bladder type tank only. If you have city water and if the city water exceeds 150 psi were does the water expand to. It doesn't it will trip your relief valve on the water heater.
Old 12-17-2009, 07:41 PM   #13
The Grand Wazoo
If the city water exceeds 150 PSI the relief valve is going to pop anyway, and I have seen plenty of well systems that would not allow expansion to make it to the tank.
Old 12-17-2009, 08:14 PM   #14
No disrespect. You need a pressure reducing valve on water that comes from the city in most cases. thats plumbing 101.
A pressure relief valve on a water heater is set 150psi and the temperature is 210 degrees or around there. If you have a well pump the max psi would be 60-70 if set up for a standard residential home and thats on the high side. When the water heats up it will expand back into the well tank.
There is no real difference between a well tank and a expansion tank.
Old 12-17-2009, 09:14 PM   #15
beenthere's Avatar
Trade: HVAC
In most of the areas I work.
Both well and city water systems require an expansion tank.
Well systems: To prevent hot water from being pushed into the well tank, and the cold water lines feeding the rest of the home.
City systems: Prevent it from being pushed into the city pipe, and into the cold water lines feeding the rest of the home.
I look at it 2 ways:
1. More money for me.
2. Helps prevents tank rupture (liner fatigue) from sudden pressure shock when faucets are suddenly slammed shut. By appliances like clothes and dishwashers.
beenthere is offline
Old 12-17-2009, 09:32 PM   #16
The Grand Wazoo
There is if the tank is isolated from the rest of the water supply system with a backflow preventer to protect the well from contamination, a very common setup here, and you're the one that started throwing out pressures without adding that a pressure reducing valve also stops the expansion on the cold water side.
But hey, it's all good, I don't know jack about this plumming crap anyhoo.
Old 12-17-2009, 09:32 PM   #17
BCConstruction's Avatar
Trade: Construction
They are basicly the same thing but the accumulators for the well water are normally a lot larger.
BCConstruction is offline
Old 12-18-2009, 08:39 AM   #18
I guess thats why there different codes for different states. I have city water and normally the water psi is 60. At night when no one is using the water it spikes. If you don't have a pressure reducing valve on the main the psi will top 150 and thats on the cold side. My water heater will blow off on psi because it cant push that 150 psi back into the street. But I have a pressure reducing valve with a built in check valve so I need some where for the expansion to go.
Again no offense. This is how things are done around here. Plus been there is right more money for us. and some water heaters wont warranty the product if there is no expansion tank, but then again they don't warranty the product if the water is hard lol.
Old 12-18-2009, 03:30 PM   #19
747's Avatar
I'm on city water. I don't have one on mine. So it definately isn't code where i live. I'm also 99 percent sure no back flow preventer. Just two copper pipes out of the wall into it. Then theres a copper pipe running to the hot water boiler sitting next to it. Of course that has a expansion tank on it. I keep that filled with 12 pounds of air.
747 is offline
Old 12-18-2009, 03:37 PM   #20
beenthere's Avatar
Trade: HVAC
Originally Posted by 747 View Post
I'm on city water. I don't have one on mine. So it definately isn't code where i live. .
or it wasn't inspected.
Water heater in basement robanderin Plumbing 23 01-07-2011 09:38 PM
Second floor water heater drip pan and T&P drains bob_cntrctr Plumbing 7 08-01-2009 10:58 PM
indirect water heater v.s. tankless world llc Plumbing 31 02-02-2009 11:28 AM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 10:58 PM
