Water Heater Connections (Water) - Braided SS, Copper Flex, SS Flex, Hard Pipe?
Old 05-25-2008, 10:09 AM   #1
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
This is one I am not quite satisfied with yet.
I have went through a stage where I hard piped every single WH I installed. (At one time I worked for a company that forbid me to even use a union.) But now that I have switched almost exclusively to PEX (Rehau or Uponor only, thank you very much!) hard piping is no longer an option.
Then I went to braided SS. But then I look at the ID and I just don't like them anymore for that reason.
So recently I have used a few copper flexes. A few years ago I would have laughed in your face if you had told me I would ever use that "crap". But right now it seems to make the most sense. But I hate myself every time I buy a set and even more every time I install them. I feel like I am putting in crap.
Any ideas?
And please don't beat me up too bad for using copper flexes. I already am doing a fine job of that myself.
22rifle is offline
Old 05-25-2008, 10:12 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Water Heater Connections (Water) - Braided SS, Copper Flex, SS Flex, Hard Pipe?
I use copper flexes all the time, nothing wrong is there use.
Ron The Plumber is offline
Old 05-25-2008, 11:08 AM   #3
Channeling Yoda out there are we?
neolitic is offline
Old 05-25-2008, 11:25 AM   #4
threaderman's Avatar
Trade: Plumbing & Gas Contractor
I use the copper as well , swt x Fip.I like to plumb them in hard in earthquake and hurricane areas but here in tornado alley the whole structure is going bye-bye anyways
threaderman is offline
Old 05-25-2008, 03:29 PM   #5
smellslike$tome's Avatar
Trade: plumbing
Cold side from top of tank: di-electric union (if you're convinced they don't work, I don't care, because it's what the IPC calls for), followed by sweat copper to a tee, from top of tee hard copper to another di-electric union to recieve expansion tank, from side outlet of tee hard piped to cold water inlet isolation valve (ball valve only), from inlet of isolation valve either hard piped the rest of the way or pex sweat adapter transitioned to pex.
Hot side from top of tank: di-electric union to hard copper or sweat pex adapter transitioned to pex.
I've never used flex lines for this simple reason; after the ho sees the flex lines installed he will think to himself something like, "this is good, the next time I have to change out this tank all I have to do is unscrew these flex lines, set the new tank in place and reconnect the flex lines" and although that is not completely true it's not far from being true.
This is the same reason that I do not use flex lines as faucet supplies, or toilet supplies, or dishwasher supplies, or refrigerator supplies, or anything else except for washing machine supplies. This and the fact that I have seen a dishwasher ss braided supply line blown completely apart except for a few strands of ss on one side of the line. The house was flooded and I have never trusted them since. I use them on clothes washers because as of now there is no better alternative.
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
Old 05-25-2008, 03:35 PM   #6
Trade: plumbing
Before someone says it just let me add that with the unions, yes, it is possible that they could do the same thing as long as the new tank is the exact height of the old tank. Also, generally, if it's a pex install, I will use a brass threaded pex adapter on the hot side and eliminate that union.
Old 05-25-2008, 03:39 PM   #7
The Grand Wazoo
KillerToiletSpider's Avatar
We pipe all the way to the washer in copper, with unions on it so you can disconnect it.
For water heaters, 8" brass nipple on the hot and cold, a brass union, and copper from there.
KillerToiletSpider is offline
Old 05-25-2008, 06:41 PM   #8
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
[quote=KillerToiletSpi;443564]We pipe all the way to the washer in copper, with unions on it so you can disconnect it.
WHAT?
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 05-25-2008, 07:34 PM   #9
22rifle's Avatar
Originally Posted by PARA1 View Post
WHAT?
That's what I said.
22rifle is offline
Old 05-25-2008, 07:51 PM   #10
The Grand Wazoo
Originally Posted by 22rifle View Post
That's what I said.
Two years ago we had a washer hose let go a month after the trim was done, on the 28th floor of a high rise co-op building, no one was home so it ran for almost a half hour till the valve got shut off. It did almost 10 million dollars in damage to the units below, luckily we used the hoses supplied with the machine, so Miele got stuck with the liability for the damage. Now we don't take chances, we pipe them in copper and use vibration unions.
Old 05-25-2008, 07:57 PM   #11
22rifle's Avatar
I spec a shut off valve if I install a washer above the first floor. Been awhile since I did that so I don't know if they are still on the market.
22rifle is offline
Old 05-25-2008, 08:25 PM   #12
Teetorbilt's Avatar
What happens when the HO decides to wash the floormats and the washer goes into the spin cycle with a wildly out of balance load?
My wife does this all of the time and the macine usually moves a few inches before you can get it shut down. I think that this would be a LOT of stress on the plumbing if it was hard plumbed plus you have altered the manufacturers design so if anything cuts loose it's your nickle.
Albert Einstein
Teetorbilt is offline
Old 05-25-2008, 08:28 PM   #13
22rifle's Avatar
Good point.
22rifle is offline
Old 05-25-2008, 08:30 PM   #14
The Grand Wazoo
We use vibration unions, the same ones used on machinery, but we probably don't need too, the washers we install are all front loads.
Old 05-25-2008, 08:31 PM   #15
22rifle's Avatar
Why so? Do you spec the washers?
22rifle is offline
Old 05-25-2008, 08:36 PM   #16
The Grand Wazoo
No.
95% of our work is very high end co-op and condo work, the designers always spec stackable washer dryers to save room, as they are getting put in a closet or under a countertop. I fight with inspectors all the time because the WMOB is installed to low, because the designer wants it under the countertop height so that it is not seen.
Old 05-25-2008, 09:08 PM   #17
Grumpyplumber's Avatar
Trade: Plumber
THere is NO try, just DO!
Grumpyplumber is offline
Old 05-25-2008, 09:10 PM   #18
neolitic is offline
Old 05-26-2008, 12:18 PM   #19
PARA1's Avatar
Trade: plumbing
Well I don't know too much about much, but this is the prefered washer for our TX low end low risers.
PARA1 is offline
Old 05-26-2008, 01:58 PM   #20
Thom
thom's Avatar
We are required to use a flex to the water heater. I hard plumbed my own house and it failed. I argued with the inspector, didn't matter. Water heaters must be connected with flex and unions.
thom is online now
Hot Water Heater 3Kings Plumbing Plumbing 8 02-03-2008 11:33 PM
Insulation water heater and hot water lines tzzzz216 Plumbing 7 02-01-2008 07:08 PM
water heater problem remodeling joe Plumbing 4 01-30-2008 12:27 AM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
water heater going bad? smitty58 Plumbing 1 01-07-2006 09:10 AM
