Water Heater In Basement
Old 12-28-2010, 02:54 AM   #21
Rob PA's Avatar
Re: Water Heater In Basement
local code for us is within 6 inches of the floor for pop off discharge with a 3/4 line...we usually use copper so there is no danger of cracking
if a floor drain is present near by and it wouldnt cause tripping hazards we would route the discharge in that direction maintaining a air gap with a union somewhere on there for reuse
Rob PA is offline
Old 01-06-2011, 03:37 PM   #22
Plumber in SC
psolutions's Avatar
Trade: Residential Plumber
I would suggest moving the water heater to another location. Possibly outside or to a garage. Also there is the option to go with a tankless unit.
Plumbing Solutions LLC
Plumber in SC
psolutions is offline
Old 01-06-2011, 04:02 PM   #23
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
An outdoor water heater would go over like a fart in a spacesuit here.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
protechplumbing (01-12-2011)
Old 01-07-2011, 08:38 PM   #24
Cobe1976's Avatar
Trade: Plumbing
You can also use pex or CPVC for the T&P relief line, as they're rated for the temperature. I take it your basement has no floor drain?
Cobe1976 is offline
Old 09-02-2015, 12:51 AM   #25
AZtimmy's Avatar
Trade: General contractor
Rewards Points: 2
mics_54, citing a trusted source, listed CPVC in accepted materials. If you aren't experienced w/ soldering copper pipe, CPVC is another very widely excepted material for the t/p line (3/4"). It is very simple to work with, relatively cheap, and can be installed in this application w/ no more than a small, fine toothed hand saw, tape measure, a piece of sandpaper, a bit of pipe dope at the threaded valve connection, and a small can of multi-purpose or CPVC glue. Much easier than copper for the DIY homeowner.
AZtimmy is offline
Old 11-05-2015, 05:43 PM   #26
mhammer's Avatar
Trade: painter
Rewards Points: 2
Does it really cost around $1500 to replace a hot water heater like this site mentions? Is it fairly easy to do it yourself since the tank is only around $500?
mhammer is offline
Old 11-05-2015, 06:39 PM   #27
mnld's Avatar
Trade: drywall junky
Rewards Points: 492
hey, it's a painter asking plumbing questions. Cue Caslon.
mnld is offline
The Following 3 Users Say Thank You to mnld For This Useful Post:
EricBrancard (11-05-2015), SmallTownGuy (11-05-2015), Tom M (11-06-2015)
Old 11-05-2015, 10:45 PM   #28
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Yeah, it could easily cost $1500 to replace one. Is it easy to do yourself? Sure, if you know what you are doing, a lot of things are easy.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
aptpupil (11-07-2015)
Water in basement EPD Carpentry 3 03-12-2009 12:50 PM
customer has new water problem in basement codaman General Discussion 22 12-02-2008 08:00 PM
water heater question smokefan203 Plumbing 15 03-07-2008 07:02 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 02:30 PM
Hot Water Joewho Plumbing 13 11-17-2006 01:39 PM
