Water Heater In Basement
Old 08-30-2009, 09:13 PM   #1
robanderin's Avatar
Trade: General B
Hello,
I was hoping for a little help,I have a 50 yr. old house in california with the water heater in the basement(original location). A inspector told me I need 1. to raise it 18" off floor...theres no way I only have like 10" from top to floor joist. and 2. plumb the T&P to the outside.
I have the line 6" off floor not sure how to get outside..have deep sink on other side of basement that I guess I could run it to but its like 15' away and it would have to be run in the joists.
any help would be appriciated
robanderin is offline
Old 08-30-2009, 09:36 PM   #2
BCConstruction's Avatar
Trade: Construction
Re: Water Heater In Basement
Originally Posted by robanderin View Post
Hello,
Your best bet would be to get a plumber around and check that out. I have never heard of having to raise a hot water cylinder of the ground by that much if at all and your temp/pressure relief should really be piped to where it cant burn anyone if it's goes off. We used to pipe them through an external wall and use a return elbow and point the pipe back toward the wall so that if there was ever a issue you would see the water coming from it and no one would get burnt from heated water.
BCConstruction is offline
Old 08-31-2009, 08:24 AM   #3
cyezza's Avatar
Trade: Home Remodeling and Inspections
Hello,
And what was the reason to raise it? When installed in garages they should be 18" off the floor because of potential gas fumes
cyezza is offline
Old 08-31-2009, 10:11 AM   #4
Thom
thom's Avatar
To many things don't make sense.
What kind of inspector was this?
Why was the inspector there?
What else is going on in the basement?
When was the water heater installed?
Who installed the water heater?
thom is online now
The Following User Says Thank You to thom For This Useful Post:
protechplumbing (01-12-2011)
Old 08-31-2009, 01:05 PM   #5
mics_54's Avatar
Trade: contractor
I'm not a plumber or inspector but I have no idea why an inspector told you the WH had to be elevated unless you basement is a garage.
The book had this to say about the temp relief piping
2006 IRC P2803.6.1 Requirements for discharge pipe. The discharge piping serving a pressure-relief valve, temperature relief lve or combination valve shall:
1. Not be directly connected to the drainage system.
2. Discharge through an air gap located in the same room as the water heater.
3. Not be smaller than the diameter of the outlet of the valve served and shall discharge full size to the air gap.
4. Serve a single relief device and shall not connect to piping serving any other relief device or equipment.
5. Discharge to the floor, to an indirect waste receptor or to the outdoors. Where discharging to the outdoors
in areas subject to freezing, discharge piping shall be first piped to an indirect waste receptor
through an air gap located in a conditioned area.
6. Discharge in a manner that does not cause personal injury or structural damage.
7. Discharge to a termination point that is readily observable by the building occupants.
8. Not be trapped.
9. Be installed to flow by gravity.
10. Not terminate more than 6 inches (152 mm) above
the floor or waste receptor.
11. Not have a threaded connection at the end of the piping.
12. Not have valves or tee fittings.
13. Be constructed of those materials listed in Section P2904.5 or materials tested, rated and approved for
such use in accordance with ASME A112.4.1
mics_54 is offline
Old 08-31-2009, 01:31 PM   #6
You did what??
J F's Avatar
I'd post the question here, lots of helpful guys(cough cough):
http://www.plumbingzone.com/f2/
J F is offline
Old 08-31-2009, 01:35 PM   #7
Illinois Licensed Plumber
SewerRatz's Avatar
Trade: Illinois Licensed Plumber
Why start trouble J F?
SewerRatz is offline
Old 08-31-2009, 01:43 PM   #8
mics_54's Avatar
Trade: contractor
Maybe I'm paranoid...but I sense that people are playing games on the forum(s)
mics_54 is offline
Old 08-31-2009, 02:13 PM   #9
JonM's Avatar
Notice all those rules but it says nothing about the discharge pipe being PVC..so it can snap at the when discharged and scald everyone nearby...
JonM is offline
Old 08-31-2009, 02:26 PM   #10
mics_54's Avatar
Trade: contractor
TABLE P2904.5
WATER DISTRIBUTION PIPE
MATERIAL ------------------------------------------------ STANDARD
Brass pipe ------------------------------------------------ ASTM B 43
Chlorinated polyvinyl chloride (CPVC) plastic pipe and tubing - ASTM D 2846; ASTM F 441; ASTM F 442; CSA B137.6
Copper or copper-alloy pipe -------------------------------- ASTM B 42; ASTM B 302
Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM) -- ASTM B 75; ASTM B 88; ASTM B 251; ASTM B 447
Cross-linked polyethylene (PEX) plastic tubing ---------------- ASTM F 877; CSA B137.5
Cross-linked polyethylene/aluminum/cross-linked polyethylene (PEX-AL-PEX) pipe - ASTM F 1281; CSACAN/CSA-B137.10
Cross-linked polyethylene/aluminum/high-density polyethylene (PEX-AL-HDPE) - ASTM F 1986
Galvanized steel pipe ---------------------------------------- ASTM A 53
Polybutylene (PB) plastic pipe and tubing --------------------- ASTM D 3309; CSA CAN3-B137.8
Polyethylene/aluminum/polyethylene (PE-AL-PE) composite pipe - ASTM F 1282
Polypropylene (PP) plastic pipe or tubing ----------------------- ASTM F 2389; CSA B137.11
Stainless steel (Type 304/304L) pipe -------------------------- ASTM A 312; ASTM A 778
Stainless steel (Type 316/316L) pipe -------------------------- ASTM A 312; ASTM A 778
PVC is not listed on the approved materials for this application.
mics_54 is offline
Old 08-31-2009, 03:15 PM   #11
You did what??
J F's Avatar
Trouble? Surely you jest...the guys over at http://www.plumbingzone.com/f2/ are nothing but helpful, courteous, kind hearted souls. Very helpful bunch.
J F is offline
Old 08-31-2009, 03:41 PM   #12
The Grand Wazoo
KillerToiletSpider's Avatar
Your judging an entire community on the actions of a few members?
Nice.
KillerToiletSpider is online now
The Following 2 Users Say Thank You to KillerToiletSpider For This Useful Post:
MACPLUMB (08-31-2009), SewerRatz (08-31-2009)
Old 08-31-2009, 03:46 PM   #13
mics_54's Avatar
Trade: contractor
here we go again...this crap gets old.
mics_54 is offline
Old 08-31-2009, 03:50 PM   #14
You did what??
J F's Avatar
Nice.
No, just the few.
J F is offline
Old 08-31-2009, 04:25 PM   #15
SewerRatz's Avatar
No, just the few.
Nice way to high jack a thread for your petty little fight.
Back to the OP concerns< I would call your local plumbing inspector and have him / her clarify what the code is for your water heater. Something just does not sound right.
Old 09-17-2009, 03:07 AM   #16
Leadworker's Avatar
Trade: Plumbing Technology
The inspector is totaly wrong or being a dick. The only reason a water heater should be 18" of the floor is if it's located in a garage or any place containing flammable liquids.
Leadworker is offline
Old 12-27-2010, 09:02 PM   #17
Azpipe's Avatar
Trade: ...
Hello,
Hopefully it's time to replace the water heater. I would want to relocate it to an above ground location. But if not, the issues can be corrected.
Is this is a gas fired water heater. It makes me think so because the 18 inches just happens to be the rule in areas where fumes can possibly build up like a garage. It does make sense to apply the same thinking in a basement. Or if there is a concern about water building up in the basement. I personally wouldn't want a fuel fired water heater under a living space. I just don't like the idea but I know it can be done, if done properly. If you don't have enough head room
then you have the wrong water heater for the application.
As far as the drain line goes, I guess drilling through the wall is out of the question. So I would secure the copper pipe to the wall or floor if there is a floor sink, and if I had to I'd install a sump and pump.
I would highly recommend having a Plumbing contractor take a look at it.
Azpipe is offline
Old 12-27-2010, 10:05 PM   #18
concretemasonry's Avatar
Trade: Masonry consultant
The P/T valve is not something to be pushed off and ignored.
The altitude record for a water heater with a frozen/jamed/obstructed valve in a one story house is about 250' after going through a the first floor and the roof structure. We had one in our neighborhood the was in a basement under a 3 story portion of the house that went over 150'. - No difference between gas and electric.
Even a home inspector should not operate or test a valve because of the life and property liability.
Dick
concretemasonry is offline
Old 12-27-2010, 10:25 PM   #19
Future Mod...
rex's Avatar
Trade: Master Plumber
No, just the few.
i agree lots of idiots over there...and i can say that cause i got banned from there for being a idiot!!! hahahahha
altho everything i said was the truth...puzzies
rex is offline
Old 12-28-2010, 12:09 AM   #20
Designer/Contractor
Rio's Avatar
As pointed out above ask the inspector to show you where in the code it says a water heater in a basement has to be 18" off the floor. That is for a gas water heater in a garage. If he can't cite the section but says he wants you to do it just because see if you can get a senior inspector to review and clarify. Good luck.
For the P&T use 3/4" copper and be sure as pointed out to run the last piece so it's pointing to the ground; maybe consider relocating the water heater to a better location. It could cause a big mess in the basement if it springs a leak.
It's not a bad idea also to use a plumber.
Rio is offline
Water in basement EPD Carpentry 3 03-12-2009 01:50 PM
customer has new water problem in basement codaman General Discussion 22 12-02-2008 09:00 PM
water heater question smokefan203 Plumbing 15 03-07-2008 08:02 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
