Wall Switch For Inline Whirlpool Heater
Old 08-11-2017, 01:13 PM   #1
remodelit's Avatar
Rewards Points: 4
Homeowner custom ordered a whirlpool tub with a built-in in-line heater. It heats the water to a 104 degrees - that is preset from the factory and not adjustable.
I can't imagine they would always want the water that hot. I'm going to suggest that we add a wall switch to turn the heater on and off. Once the tub is installed, the access panel will be tiled in place so its going to require cutting out the grout to get access to the tub. The outlet for the heater is wired to a GFCI breaker in the main panel.
Have you ever wired one of these heaters on a wall switch? I see no reason why that wouldn't work.
remodelit is offline
Old 08-11-2017, 06:28 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,140
Re: Wall Switch For Inline Whirlpool Heater
Sure, it would work. But do you want the liability of what could happen when the homeowner's sitting in the water and reaches up to flip that switch?
Most of those heaters only run while the pump is running. If it's getting too warm, just shut the pump off and soak for a while.
I'd also recommend against sealing that access panel. If the unit needs service (and they all do sooner or later), you are building in extra time and money to accomplish that.
Tinstaafl is offline
Old 08-11-2017, 08:33 PM   #3
remodelit's Avatar
Rewards Points: 4
Thanks for the reply!
I'm sorry, I should have mentioned that the switch would be beyond reach from inside the tub. I assumed it would either be on or off for the duration of their bath. I mainly was wondering if anyone else had run into this situation and elected to add a switch.
Old 08-15-2017, 10:56 AM   #4
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 3,262
In order for the thermostat to work it needs to know the temperature of the water, unless it's timer of some kind. Customer ordered a non adjustable heater, why get involved? I sure wouldn't.
RangoWA is online now
Old 08-15-2017, 08:53 PM   #5
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,430
It's possible that the water in the tubes will be maintened at the set temp, and they don't want to heat it. That may throw off how well the tub heating system works, but,...
I don't think the op is putting themselves out by wring a wall switch, as long as it done up to code. But, one may want to make sure the switch doesn't effect how well the tub gets heated.
http://www.37flash.com/
flashheatingand is offline
Old 08-16-2017, 07:57 AM   #6
RangoWA's Avatar
Trade: Tool jocky
I don't understand why it doesn't have a switch anyway. Is it always heated? I'll stick with the ole water heater method.
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 01:14 PM
Heat Shield For Wall Heater Seven-Delta-FortyOne HVAC 2 08-03-2013 03:08 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 11:56 PM
Masonry Wall Art Picbrick junie General Discussion 4 07-26-2012 04:51 PM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 10:58 PM
