W.C. Weeping , Feed Back Please
Old 01-21-2008, 11:03 PM   #1
Plumber
tzzzz216's Avatar
Trade: Plumbing
I have a customer with a kohler water closet 2nd floor bathroom , the water in bowl keeps weeping out no sign of water on the floor or even stoppage in the line , I installed a new flapper and valve , I also put in dye to see if the tank was leaking not a drop of dye showed up in the bowl ,I'm still leaning towards a stoppage or even a vent problem thats sucking the water out , FYI the house is about 35 years old ,The customer stated that the water level in the bowl stated up for about 3 hours after I left the job .
Thanks in advance !!
tzzzz216 is offline
Old 01-21-2008, 11:13 PM   #2
Al Smith
A W Smith's Avatar
Re: W.C. Weeping , Feed Back Please
if there is a rag or string like fabric stuck in the tight turn of the WC trap if could be wicking water down the waste. Or there could be a defect or crack from power augering within the tight turn of the trap that would not be visible but leak down the waste as well.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-21-2008, 11:27 PM   #3
Plumber
tzzzz216's Avatar
Trade: Plumbing
Thanks A.W. for the feed back I haven't pulled the bowl yet or snake it out, but i'll check it out ,Thanks again !!
tzzzz216 is offline
What's in your wallet -or- my back hurts mdshunk Health & Safety 19 04-26-2007 10:49 AM
Laying hardwood floor, any tips for saving my back? Dustball Flooring 11 03-26-2007 02:41 PM
back button javascript code Mike Finley Technology 2 06-27-2006 12:43 PM
gravity feed Vermonster HVAC 8 02-10-2006 07:49 AM
Need some feed back guys . . . Dually vs Single rear wheel. MEI MRG MM Vehicles 6 01-22-2006 03:21 PM
