Venting For Toilet Dillema
Old 11-11-2008, 11:28 PM   #1
fumbrunner's Avatar
Trade: general contractor
Hi, got a quick question on a house that I am renovating. I will be calling in a plumber to potentially solve this problem, but wanted to get a sense of my options.
The house has two stacks (not sure why). Most of the existing plumbing goes through one stack, which is fine. The second stack has only a 1st floor toilet running into it. The stack looked like it ran horizontal with the 1st floor joists and then up the wall. Upon further review, there is no vent coming through the roof and nothing out the side of the wall. Apparently the vent goes horizontal and then no where.
Obviously the toilet is not flushing properly since it is not vented properly. Can that stack be vented out the side of the house? Is an AAV an option here? Is my only option to have the plumbing run into the other stack (which is not the greatest option because of the position furnace and HWT). Wanted to get some feedback prior to calling a plumber.
fumbrunner is offline
Old 11-11-2008, 11:36 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Venting For Toilet Dillema
Would be nice to know where your at, this will help on determining with code you use.
Ron The Plumber is offline
Old 11-11-2008, 11:40 PM   #3
fumbrunner's Avatar
Manitoba, Canada
Old 11-11-2008, 11:41 PM   #4
Pro Plumber
Trade: Plumber
Well not in my neck of the woods, so I can't help you, Sorry
Old 11-12-2008, 10:42 PM   #5
fumbrunner's Avatar
Thanks anyways Ron. Anyone else have a suggestion? Is it possible to do a 2" take off from the Toilet line and add a AAV?
Old 11-13-2008, 12:22 AM   #6
orange Garrison's Avatar
Trade: general contracting/carpentry
I would definatly say that someone has f--ked some plumbing up in the past?I think you should check all plumbing with the help of a qualified and EXPERIANCED plumber!there may be more problems there than you think . when was house built?
orange Garrison is offline
Old 11-13-2008, 04:27 AM   #7
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
I thought they all had to vent to the roof. I'll also be the first to admit I know nothing about plumbing and rely too much on my plumber's knowledge on everything...
Winchester is offline
Old 11-13-2008, 08:09 AM   #8
threaderman's Avatar
Trade: Plumbing & Gas Contractor
It sounds like you're trying to do this your-self,get someone licensed,sorry,too many jobs lost because "the GC took care of it",play by the rules man.
threaderman is offline
Old 11-13-2008, 10:29 AM   #9
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
fumbrunner:
I am not in Canada, but pretty much you would have to
1. Vent to your other stack or
2. try to somehow go up thru the roof.
That would be your best and safest bet. AAV are not reccomended and against code in many places. As for going thru the wall You can ask a local plumber or inspector to see if it would be acceptable. In many places it is not, thus I would not reccomend, but of course the final desition is yours.
Hope this helps, please post what plumber or inspector told you for future knowledge.
A.D. Const is offline
Old 11-13-2008, 12:15 PM   #10
fumbrunner's Avatar
Thanks guys. Had my plumber in today and his recommendation is to have it run to the other stack. It's going to take away some room in the basement, but we do not have any other options. Cant vent to outside wall, cant use AAV. Just wanted to make sure that he was giving me good advice, and given the posts here, it sounds like he is right on.
Thanks.
Old 11-13-2008, 12:16 PM   #11
fumbrunner's Avatar
It was built in the early 1900s but has some considerable DIY work on it that I have had to largely undo
Old 11-18-2008, 12:03 AM   #12
good stuff glad to hear that your have your solution stay cool and well vented ...LOL Garrison
Old 11-18-2008, 01:06 AM   #13
remember venting code has changed since 1905!! lol
venting a wood stove with other things walshwoodworkin Construction 7 11-05-2008 09:17 AM
Retro venting flashheatingand HVAC 1 10-25-2008 12:40 PM
roof venting repair Home Serve Roofing 0 09-08-2008 09:44 PM
Dryer/HVAC venting Kevin75 HVAC 17 08-28-2008 08:09 PM
Heating Oil Tank Venting RenaissanceR HVAC 1 01-02-2008 07:41 PM
