Venting 1/2 Bath On 1st Floor
Old 09-29-2007, 01:52 PM   #1
samiam's Avatar
Trade: painter
i am adding a 1/2 bath on my first floor
but not doing anything on the 2nd floor so a roof vent will not work
how do i go about venting this to meet code
thanks
samiam is offline
Old 09-29-2007, 02:01 PM   #2
Future Mod...
rex's Avatar
Trade: Master Plumber
Re: Venting 1/2 Bath On 1st Floor
you could use a AAV depending on were you live....im not a fan of them but if code allows it....it is a good option
rex is online now
Old 09-29-2007, 02:09 PM   #3
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
the code states that as long as you have at least one vent through the roof, then all other fixtures can be vented with a air admittance valve (AAV) as long as it is a code approved AAV, not one of those spring operated trailer vents. Studor is the brand I use.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-29-2007, 04:24 PM   #4
samiam's Avatar
Trade: painter
were does that exactly go
and does it need to be above the level of the toilet of can it be in the ceiling below
can i come off a 3' 90 with a 1 1/2" line and 90 it up in between the joist
samiam is offline
Old 09-29-2007, 04:33 PM   #5
Plumber / Carpenter
Bill's Avatar
If you are going to put one on the sink, go to your local plumbing wholesale store (Not home depot, or lowes0 and ask for the P-Trap with built in AAV. You install it just like a regular P-Trap
Bill is offline
Old 09-29-2007, 04:49 PM   #6
samiam's Avatar
Trade: painter
thanks
samiam is offline
Old 09-29-2007, 08:00 PM   #7
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
I don't know what code you guys go by or where you can put an AAV below the flood level rim of any sink but it sure won't fly with NSPC in NJ
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 09-29-2007, 08:17 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Mechanical vents do not meet code here.
KillerToiletSpider is offline
Old 09-29-2007, 08:21 PM   #9
Plumber / Carpenter
Bill's Avatar
Virginia. Also if you look at the international plumbing code and see how to connect an island sink. The AAV would have to go below the flood rim of the sink, where else can you put it at?? And you have to vent the sink, right? after all the national code says all fixtures and traps must be vented
Bill is offline
Old 09-29-2007, 09:05 PM   #10
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Where is nepa?
Ron The Plumber is offline
Old 09-29-2007, 09:10 PM   #11
The Grand Wazoo
Here you have to run an island sink vent, and reconnect it at 42" AFF, with a crossover between the waste and vent to drain the vent if the waste gets blocked.
Old 09-29-2007, 11:53 PM   #12
samiam's Avatar
Trade: painter
north east PA
samiam is offline
Old 09-30-2007, 12:02 AM   #13
Pro Plumber
Trade: Plumber
Studor vents are approved there, here there not.
Old 09-30-2007, 09:21 AM   #14
Plumber / Carpenter
Bill's Avatar
Thanks for the info, did not realize that it was different in NJ. Live and learn!
Bill is offline
Old 09-30-2007, 09:44 AM   #15
samiam's Avatar
Trade: painter
i now have my kitchen gutted and realized the kitchen sink isn't vented at all
never had any real issues with it?? the only vent is 1 1/2 with 3 fixtures should i change this to a 2" and see if i can get the kitchen to it and i think i might be able to get the 1/2 bath to it with a little extra work
this would now be 6 fixtures
the top of the vent pipe only sticks out of the roof about a foot and its not above the toilet tank but it is above the bowl?? is this alright or ahould it be higher
thanks
samiam is offline
Old 09-30-2007, 09:49 AM   #16
Pro Plumber
Trade: Plumber
Change the vent to 2" which is min size here, check your code for toilet vent size.
New Concrete Floor laid, cracking, and sealer Q's. Knyte260 Construction 21 10-07-2007 12:25 AM
SOS bath remodel: bizarre floor situation zmusashi General Discussion 9 07-29-2007 10:54 AM
Bathroom floor question Eric K Flooring 18 02-18-2007 06:17 PM
Basement floor dilemma ron schenker Flooring 11 07-02-2006 09:36 PM
overhead poured floor landmark Masonry 6 03-03-2006 03:53 PM
