Vent Problem
Old 12-29-2017, 07:08 PM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 958
Vent Problem
My sister lives in the country like I do on a septic system. Washer drains into a separate tank/system. Anyhow her vent stack frost up and freezes shut when it is really cold below zero and steam comes out of it when not plugged. Doesn't shower excessively, just her and boyfriend. Now mine has never done that and we live only a few blocks apart. Asked a plumber here I know , no clue. so just wondering if any of you here have ever ran across something like this.
Thanks
Randy Bush is offline
Old 12-29-2017, 07:47 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,300
Re: Vent Problem
Hang a candy cane shaped piece of 3/4" copper in it, extending well into the heated portion. That can keep it from freezing shut.
If it's not already 4", you could up the size as well.
Have as little as code allows above the roofline and insulate as high as you can.
These are all solutions that were implemented when I lived in Fairbanks, one of the colder regions of Alaska.
Golden view is offline
Randy Bush (12-29-2017)
Old 12-29-2017, 08:08 PM   #3
Randy Bush's Avatar
Rewards Points: 958
Re: Vent Problem
Thanks will give that a try. It is just funny hers does it and mine don't.
Old 12-29-2017, 08:27 PM   #4
edward trowelhands
Trade: Diplomat
Re: Vent Problem
It was like that in FBX too. Some were problematic. Maybe extra active septic tank wee beasties.
Old 12-29-2017, 08:46 PM   #5
tjbnwi's Avatar
Rewards Points: 3,408
Re: Vent Problem
Yours may be a 4 hers may be a 3.
tjbnwi is offline
Old 12-29-2017, 10:24 PM   #6
BattleBornNV's Avatar
Trade: General contractor
Rewards Points: 372
Re: Vent Problem
Check the attic insulation depth around the the vent stack(s). If blown in, could suffer from settling and or various maintenance/remodel/repairs over the years that may have displaced.
Just a thought, adding to the above ideas
BattleBornNV is offline
The Following User Says Thank You to BattleBornNV For This Useful Post:
Major Water Condensation in Furnace Flue Vent in Attic - Drywall Damage seaweed HVAC 11 01-13-2014 07:51 PM
Vent install gav_sharma Remodeling 2 10-05-2013 08:14 AM
problem with a large order of pond products Outdr Contractr General Discussion 6 12-20-2012 06:51 AM
FHW heating system problem porterbruce HVAC 8 11-25-2012 10:45 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
