Vent Distances
Old 10-13-2008, 07:32 PM   #1
Philly Dude's Avatar
Vent Distances
My reference books tell me that maximum distance traps can be from a vent are:
Pipe size Distance to vent
1 1/2" 3 1/2'
2" 5'
3" 6'
4" 10'
I've worked in many houses there is no vent that I can see that would be within these distance limits. In many cases there would be no possible route that a pipe could get back to the stack within these distances. I guess what I'm asking is, is this common and not really a problem ? Or are these all cases of unpermitted work or lax inspectors ?
Philly Dude is offline
Old 10-13-2008, 07:33 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Vent Distances
rbsremodeling is offline
Old 10-13-2008, 07:38 PM   #3
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Vent Distances
1 1/2" 3 1/2'
2" 5'
3" 6'
4" 10'
Can't speak for Philly, but it may be older than when this requirement hit their code. Or, knowing what kind of reputation Philly inspectors have, who knows?
Another possibility is that you aren't understanding what you are seeing. It could be meeting code but not look like what you are used to seeing.
22rifle is offline
Old 10-13-2008, 09:27 PM   #4
jjaplumbing's Avatar
Trade: Plumbing
Re: Vent Distances
Philly Dude, obviously not a registered plumber, but your distances are way off. Philly has its own code. Small fixtures can be a maximum of 12 feet from a vented line and large fixtures can be a maximum of 8 feet from a vented line. Large fixture: toilet, small fixture: mostly anything else. These distances only apply in the city once you go into Bucks, Montco, Delaware and Chester counties it is BOCA or national or whatever they are calling it today.
jjaplumbing is offline
Old 10-14-2008, 01:13 AM   #5
Re: Vent Distances
jja : I see the 8' and 12' numbers in section 1105.2 of Philly's plumbing code. Is that what you are referring to ?
Old 10-14-2008, 09:35 AM   #6
Remodeling GC
kevjob's Avatar
Re: Vent Distances
Here in denver the inspectors tell me 5 feet for 1.5 inch and 8 feet for 2 inch
kevjob is offline
Old 10-14-2008, 09:37 PM   #7
Trade: Plumbing
Re: Vent Distances
section 1105.2 exactly. If you go over the distances you can revent at half the size of the pipe (1.5 min.) , unless there are 2 fixtures then you must revent at full size.
Old 10-14-2008, 09:47 PM   #8
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Vent Distances
1 1/2" 3 1/2'
2" 5'
3" 6'
4" 10'
That is what my code tells me.
Ron The Plumber is offline
Old 10-15-2008, 04:43 PM   #9
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
Re: Vent Distances
Idaho is under the 2003 UPC
1 1/4" -2' 6"
1 1/2 -3' 6"
2"- 5'
3"- 6'
4" -10'
Moscow is offline
Old 10-15-2008, 04:51 PM   #10
DavidC
DavidC's Avatar
Re: Vent Distances
My house (circa 1864) was never vented until I added one just before the main leaves the house. I'll be adding another when I put a 1/2 bath in the office. All I need to start is a round toit.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-15-2008, 06:56 PM   #11
Pro Plumber
Trade: Plumber
Re: Vent Distances
1 1/4" -2' 6"
Where do you get 1-1/4" DWV at, I can't find any here.
Old 10-15-2008, 08:08 PM   #12
rombo's Avatar
Trade: Plumber
Re: Vent Distances
You can get it where I am but it is more expensive than 1 1/2" in most cases so there is really no use for it
rombo is offline
Old 11-02-2008, 12:51 AM   #13
Grumpyplumber's Avatar
Trade: Plumber
Re: Vent Distances
Hell, even HD has it here.
Grumpyplumber is offline
Powered Gable Vent vs. Powered Rooftop Ventilator redzthredz HVAC 6 06-15-2010 05:49 AM
Bad plumbing vent pipe flashing Webman12 Roofing 5 10-08-2008 08:22 AM
ridge vent industry question USER8493893 Roofing 24 09-28-2008 01:52 PM
Range Downdraft Vent DEKAN Kitchens & Baths 1 09-05-2008 09:17 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
