Trade: Remodeling / Carpentry
Vanity Install ?
Doing a bsmt reno that a 36" vanity and cultured marble top will be installed.
Yes, I did pull a permit and the plumber will be doing the install. I've seen these installed so many different ways, caulk on the edge of the vanity top, caulk behind the back splash then squished into the wall.... Just want to see how you guys install ? I suppose all install methods - undoing it after 6 months or so is fubr ? Last edited by We Fix Houses; 02-28-2010 at 11:45 AM. |
The Grand Wazoo
Re: Vanity Install ?
Level the cabinet and attach it to the backing in the wall if the carpenter did not already install it, run a bead of acrylic adhesive caulk all the way around the top edge of the cabinet and set the marble top on top of that, then run a bead of caulk around the backsplash to keep moisture out.
Trade: home remodel/repair
a few dabs of silicone on top of vanity will hold good, be sure to do it where it is accessable. i've done alot of these and the worst is when you can't get at it when it to cut/pry when it has to be removed
Trade: plumbing/electrical/hvac
wheres your revent on that waste arm?seems a little far to me anyway
#5 | |
Re: Vanity Install ?Quote:
I suggested an AAV in the vanity? He met the inspector there for the R/I insp. It passed. Last edited by We Fix Houses; 02-28-2010 at 12:17 PM. |
| Restoration Hardware C-top install | Greg Di | Kitchens & Baths | 12 | 09-15-2009 11:34 PM |
| Vanity Toekick Space Step-stool/Storage | basswood | Finish Carpentry | 52 | 03-29-2009 09:02 AM |
| Island cabinet install | not2late | Finish Carpentry | 3 | 03-15-2009 08:10 PM |
| Window Install Questions | Brickie | Windows, Siding and Doors | 9 | 02-21-2009 06:34 PM |
| Pond Water-Leveling Pipe Install | Trencher | Excavation & Site Work | 7 | 12-26-2008 12:28 AM |
