Is The Underground Pipe Layout Correct?
Old 02-01-2008, 06:10 PM   #1
stoneweed1's Avatar
Trade: wiring
This is my first attempt ever at installing underground pipes for a full bath in the basement and i'd like to know if:
1) Is the shower (far right 2" pipe) properly vented? Am i correct to assume that the shower is properly vented because the sink drain is between the toilet and the shower?
2) If the shower trap looks good? Or did i create an s-trap?
3) When I pour the 4" of concrete in the shower area to close it, whats the best way to do it? the concern is that the majority of the trap would be concreted and enveloped in that area. is this method okay or is there an alternative way?
4) Must one reinstall a vapor barrier below the concrete once finished? i didn't install a vapor barrier in this case.
5) Overall does it look fine? I already concreted everything up except for the shower trap area.
So from left to right it is sink, toilet, and shower. the sink will drain into the main stack. the main stack then goes down under the concrete and sweeps to the right and connects to the 3" toilet drain approx 1 foot to the right of where toilet flange would be. This would vent the toilet and the shower. The toilet drain then continues to the right and then the shower p trap appears and drains into the 3" drain that originates from the toilet drain. The distance from the shower drain to what I presume is the vent is approx 4 feet. The graph paper diagram shows it better.
Thanks in advance.
is the underground pipe layout correct?-dsc00456b.jpg   is the underground pipe layout correct?-pipe-undergrounda.jpg   is the underground pipe layout correct?-basement-002a.jpg
stoneweed1 is offline
Old 02-01-2008, 07:04 PM   #2
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
Re: Is The Underground Pipe Layout Correct?
WHEN ARE YOU GOING TO START THIS JOB?, OR SHOULD I ASK WHEN ARE YOU GOING TO REDO THIS JOB.
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 02-01-2008, 07:08 PM   #3
threaderman's Avatar
Trade: Plumbing & Gas Contractor
Never ceases to amaze me.First post and people want to take and not give.
threaderman is offline
Old 02-01-2008, 07:10 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
I don't see any proper vents.
KillerToiletSpider is offline
Old 02-01-2008, 07:17 PM   #5
stoneweed1's Avatar
Trade: wiring
would appreciate the advice since its done incorrectly
Old 02-01-2008, 07:19 PM   #6
Thom
thom's Avatar
better pick up the book over at HD.
thom is offline
Old 02-01-2008, 07:32 PM   #7
stoneweed1's Avatar
Trade: wiring
to the right of the toilet 3" drain is a vent that runs to the left and up the wall?
and the shower uses the same vent?
Old 02-01-2008, 07:44 PM   #8
The Grand Wazoo
You have a wet vented toilet and an unvented shower with an illegal s-trap.
Call a plumber.
Old 02-01-2008, 08:26 PM   #9
stoneweed1's Avatar
Trade: wiring
so is this what the redo should look like?
toilet has Vent2 about 12 inches downstream
shower has Vent3 about 12 inches downstream from where the p trap ties into the 3" drain.
thanks
Old 02-01-2008, 08:37 PM   #10
The Grand Wazoo
No.
Seriously, call a plumber.
Old 02-01-2008, 08:41 PM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Call a plumber, your all screwed up.
Ron The Plumber is offline
Old 02-01-2008, 08:54 PM   #12
PARA1's Avatar
Trade: plumbing
That's probably up to code in OKLAHOMA
PARA1 is offline
Old 02-01-2008, 08:55 PM   #13
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Ever see a homeowner do a "wire for fire"? This is what we see,get a plumber.
No Dis. meant,fact.
Driftwood is offline
Old 02-01-2008, 09:07 PM   #14
The state and every city I work in are all using 2006 IPC ,IRC,IFGC .It's fairly strict ,but good.I really appreciate the new venting codes.Don't you use the international codes?Do you have public sewer and water systems in Fort Worth?
Old 02-01-2008, 09:10 PM   #15
stoneweed1's Avatar
Trade: wiring
how would you vent then?
Old 02-01-2008, 09:10 PM   #16
The Grand Wazoo
They have a code for the size of the crescent cutout on the outhouse door.
Old 02-01-2008, 09:13 PM   #17
You guys are ornery tonight,better go git you some!
Old 02-01-2008, 09:19 PM   #18
The Grand Wazoo
I'd do it right, but I also went to school for three years and apprenticed for five to learn how to do it.
Old 02-01-2008, 09:22 PM   #19
Pro Plumber
Trade: Plumber
Look it up in the code.
Old 02-01-2008, 09:59 PM   #20
Putty Truck's Avatar
Trade: hjrafiuoashfed
Dang, stonerweed, you are thick.
Imagine this: you in all your finery walk into a bar full of construction workers and start asking questions, right? Everyone tells you to get lost, but you continue on asking questions.
What would the scenario be when the man who refers to hisself as "da plumba" turns away from his glass to address you and your freakin' questions?
What?
Putty Truck is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
Old black water pipe pedro mac Plumbing 4 12-28-2005 04:13 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
