Under Slab Leak??
Old 03-16-2010, 10:50 PM   #1
220/221's Avatar
Trade: electrician Phoenix AZ
Under Slab Leak??
What kind of equipment do prfessionals use to detect under slab leaks?
Is it a listening device of some sort?
I have a good sized under slab hot water leak under in a rental condo of mine. The noise is very apparent in the back to back bathroom wallss. It is as loud as say, when the toilet is refilling, but since there is no water showing, it's obviously going out under the slab.
My plan is to remove the 30" wide vanity cabinet and jackhammer the floor to access the leak but I want to be more certain that the leak is close by.
Should I spend the $150 for a leak locator service of just proceed? I can easily do the repairs but if the leak is 10 feet away under the carpeted living room floor, I don't want to mess with removing/replacing the vanity.
It sounds awfully close to the bathroom but?????
Crap. I suppose I just need to cough up the $150. In the old days ( a couple years ago) I wouldn't think twice about it but work (electrical ) is still slow as hell and $150 is more important than it used to be.
Any input will be apreciated. I have to decide tonight and call a locator tomorrow.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 03-16-2010, 10:53 PM   #2
Project Superintendent
mudpad's Avatar
Re: Under Slab Leak??
If you can get a competent leak detector to find your leak for $150 you should jump on it. Around here they get $500 minimum.
mudpad is offline
Old 03-16-2010, 11:10 PM   #3
calhomeremodel's Avatar
Trade: general contractor
Definately go with the leak detector. The sound can be decieving.
calhomeremodel is offline
Old 03-16-2010, 11:21 PM   #4
220/221's Avatar
Yeah, that's what I'm thinking. I was just looking for another set of eyes on the issue. Thanks.
Actually, I hope it's in the living room. The carpet will be easier to deal with than the vanity.
220/221 is offline
Old 03-18-2010, 03:59 AM   #5
peterjames's Avatar
Trade: licensed plumber
There are two methods of leak detection. Unless you're a plumber, happen to own a geophone or an extreme DIYer, call on the pros.
By applying the geophone -- an electronic listening device -- an operator can actually hear water dripping or flowing. By using the device around plumbing, the operator can identify where water is moving out of the system.
another method of leak detection, is leak detection via pressure testing equipment. Again, it takes know-how and additional equipment to conduct a pressure test. Your wisest move is to hire builder, plumbing contractor or leak detection company that has the right stuff to do the job.
peterjames is offline
Old 03-19-2010, 07:52 PM   #6
220/221's Avatar
Split copper, right where I thought it was, under the vanity cabinet.
$185 bucks "wasted".
220/221 is offline
Old 03-19-2010, 10:35 PM   #7
BCConstruction's Avatar
Trade: Construction
Thats always the way. But still a good price.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 03-20-2010, 12:19 AM   #8
SEMI RETIRED
griz's Avatar
But you didn't know that, so what was wasted?
If you thought that why didn't you act on it?
griz is offline
Old 03-20-2010, 07:49 AM   #9
Thom
thom's Avatar
My dad (rip) was confident he knew where the leak was under his slab. He could hear it clearly at that point, in the middle of the house. I scheduled to go tear up the slab and fix it but before I got there the leak surfaced in a big way, in the front yard.
Sound can travel through those copper water pipes quite well.
thom is offline
Old 03-20-2010, 12:45 PM   #10
The Grand Wazoo
KillerToiletSpider's Avatar
I've been able to find leaks on hot water using an infrared pyrometer, find the hottest spot in the slab and you usually have found your leak.
KillerToiletSpider is offline
Help,under slab hot water leak BE001 Plumbing Picture Post 8 02-20-2010 10:26 PM
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 08:25 PM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 05:42 AM
HELP!!! Leak under exterior wall on slab jrcuts General Discussion 4 01-09-2009 07:21 PM
leak under sunroom exterior wall on slab jrcuts Framing 7 01-09-2009 06:17 PM
