Tub Spout /Diverter
Old 09-25-2011, 07:56 PM   #1
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
Tub Spout /Diverter
Hey Guys...I recently installed two new bathrooms in the same house. The tub spout/diverter in both bathtubs allows water to come out of the shower head while the diverter is in the "tub"position. Obviously the tub spouts can be changed easy enough, but I was wondering if anyone else has encountered the same problem. Both of the the shower valves are brand new as well.. Thanks in advance......
EMINNYS is offline
Old 09-25-2011, 07:59 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
Re: Tub Spout /Diverter
You installed the valve bodies upside down
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 09-25-2011, 08:00 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
Send a message via Skype™ to ChrWright
What kind of valves?
Sounds like the valves may have been installed upside down.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 09-25-2011, 08:01 PM   #4
Tech Dawg's Avatar
...well, I hope you didn't... an upside down installation is the only way I've ever heard of this problem.
Todd
Old 09-25-2011, 08:05 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,104
I did that once.
Tinstaafl is offline
Old 09-25-2011, 08:11 PM   #6
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
Thanks guys....but the valves are definitely not installed upside down....What about water pressure, could that create this problem, if the pressure was too high?
EMINNYS is offline
Old 09-25-2011, 08:13 PM   #7
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
what kinda pipe did you use??
what brand valve ?
rex is offline
Old 09-25-2011, 08:16 PM   #8
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
what brand valve ?
Thanks rex.....I am pretty sure they were Moen "Caldwell" valves(single handled).... Pex was used as the supply pipe, and there was no soldering done near the valve....(pex male adapters were used)... Also the valves are pressure balanced valves.
EMINNYS is offline
Old 09-25-2011, 08:17 PM   #9
rex's Avatar
Trade: Nothing
did you use pex for the spout drop?
rex is offline
Old 09-25-2011, 08:20 PM   #10
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
pex used to drop down to a pex drop ear 90, and then brass nipple.....
EMINNYS is offline
Old 09-25-2011, 08:22 PM   #11
Tech Dawg's Avatar
Cannot be pex... must be a minimum of 1/2" copper
Todd
Old 09-25-2011, 08:22 PM   #12
rex's Avatar
Trade: Nothing
not good dude...the valve dumps more water than the ID of the pex can flow so the water goes up to the shower head...
rex is offline
Old 09-25-2011, 08:28 PM   #13
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
Yikes....That sound like it makes sense.....I have done them his way before and not had a problem....but this seems to make sense..... It looks like I will be installing a diverter on the shower arms.....
So when you guys install using pex, do you just stub down with copper??? Great Info Thanks!!
EMINNYS is offline
Old 09-25-2011, 08:31 PM   #14
Tech Dawg's Avatar
Sweat the copper to the down port or use a female adapter X 1/2" sweat.
Todd
Old 09-25-2011, 08:31 PM   #15
rex's Avatar
Trade: Nothing
yea you can buy moen/delta valves in PEX and the only PEX ports are hot and cold
i use copper for the head and spout..
although id rather get a full sweat valve and stub cooper out and adapt to PEX on the hot and cold
rex is offline
Old 09-25-2011, 08:34 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,602
Is that what they call "Stacking"?
IIRC when I RTFM it said it has to be copper of galvanized only. Before I read that I had my PEX crimper ready to go!
Inner10 is offline
Old 09-25-2011, 08:36 PM   #17
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
Rex.....Thanks a million....your answer was immediate and seems like the problem.... At least we got past the "valve installed upside down" although I feel just as humbled... What do you think of my diverter on the shower arm idea?
EMINNYS is offline
Old 09-25-2011, 08:37 PM   #18
Tech Dawg's Avatar
Good job Rex!!!
Todd
The Following User Says Thank You to Tech Dawg For This Useful Post:
rex (09-25-2011)
Old 09-25-2011, 08:38 PM   #19
EMINNYS's Avatar
Trade: REMODELER
Rewards Points: 258
Shame on me for not reading the manual.....I have installed so many valves, going all the way back to the early 80's, that I stopped reading the manuals.....
EMINNYS is offline
Old 09-25-2011, 08:40 PM   #20
rex's Avatar
Trade: Nothing
i dont like it at all and i bet the homeowners wont like it either..
would cutting the wall behind be possible? thats really the right way
rex is offline
Ice in gutters and down spout davinci Roofing 31 02-02-2011 01:03 PM
Tub Spout Stub Out ? We Fix Houses Plumbing 7 06-15-2010 08:18 PM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 09:42 PM
New Tub Spout Rick Bruner Plumbing 2 12-17-2007 10:42 PM
Bathub spout kathyh Plumbing 1 06-30-2005 04:53 PM
