Tub Removal?
Old 12-17-2008, 10:17 PM   #1
rotarex's Avatar
Tub Removal?
hey guys i already removed the tub, but i want to know for next time, i have the fork, but this time i broke all the pieces in the drain, so i cut a hole at the bottom and cut out the pipes, but if i had to repair the subfloor this would have been a problem
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 12-17-2008, 10:23 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Tub Removal?
Dynamite.
Works every time.
KillerToiletSpider is offline
Old 12-17-2008, 11:21 PM   #3
rotarex's Avatar
Re: Tub Removal?
Originally Posted by KillerToiletSpider View Post
Dynamite.
Works every time.
its Canada, we barely have fire crackers here
Custom Decks
Renovation
rotarex is offline
Old 12-17-2008, 11:32 PM   #4
The Grand Wazoo
Re: Tub Removal?
Get a copy of the the book "An Anarchist's Cookbook", you can make your own in your kitchen using household items available from the hardware store.
Old 12-18-2008, 12:56 AM   #5
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Tub Removal?
I don't understand what you saying here, are you talk about the cross seen in the tub shoe, if so it happens, when that happens you have to find another way to remove it, I have a special tool that will expand and tighten against the tub shoe wall, this allowing me to remove the shoe. But you won't find this tool just anywhere and I'm not sure it's even made anymore.
Ron The Plumber is offline
Old 12-18-2008, 01:02 AM   #6
mickeyco's Avatar
Trade: Squirrel Handler
Re: Tub Removal?
link
Tail pipe/muffler expander will work as well.
mickeyco is offline
Old 12-18-2008, 01:04 AM   #7
Pro Plumber
Trade: Plumber
Re: Tub Removal?
Originally Posted by mickeyco View Post
link
Mine don't look that that but that can work also.
Old 12-18-2008, 06:34 AM   #8
rotarex's Avatar
Re: Tub Removal?
yes that tool make sense, looks like you can put a socket / monkey wrench on that one, my next tub job is a looooong way from now i gotta rember to get that tool, the stupid tuning fork thing, got no torque and when a tub has been in place for 30 yrs, for sure its stuck
Custom Decks
Renovation
rotarex is offline
Old 12-18-2008, 07:45 AM   #9
He who's held accountable
Terrorron's Avatar
Trade: General Contractor-Renovations
Lightbulb
Re: Tub Removal?
A "disposable" wood chisel, 16oz hammer, and a pair of safety glasses...
The chisel should be sharp enough to notch into the outside edge of the plug basket
(but not so sharp that it cuts right thru it in a couple of whacks). I usually notch/whack in the same manner as tightening a five bolt rim (star pattern); if it's not moving by the time you've got five notches into it...
...see above comment regarding explosives (I'd recommend a 1/2lb shaped-charge, myself)
Obviously this only works when the tub's being replaced.
Do not ignore the safety glasses...one flying shard of porcelain in the wrong place can really wreck your day.
Cheers, Ron
Terrorron is offline
Old 12-18-2008, 08:12 AM   #10
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
Re: Tub Removal?
The great little handy helper works great on the tub shoe as well as broken toilet flanges needing to be replaced.
Yup you guessed it, it is what the RCH is attached to, oops wrong item.
oh yeah here it is
A dremel with the carbide wheel works every time on the old brass drain pipes & pvc toilet flanges..
with the cross hairs out of the shoe, cut just below the heavy metal of the shoe into the softer brass tube, cuts nice.
The old cast iron tubs I then give to a local guy who does reglazing & sells the tubs again. This way anytime I need a favor he reglazes tubs or sinks for me for free.
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 12-18-2008, 08:37 AM   #11
Terrorron's Avatar
Re: Tub Removal?
oh yeah here it is
Good one...non-destructive to the tub (although I've [as yet, as a remodeler] not encountered one where getting the tub out in pristine condition was a requirement).
I'll definately use the Dremel if (when) I come across this situation...
Cheers, Ron
Old 12-18-2008, 10:25 AM   #12
Burby's Avatar
Re: Tub Removal?
Cheers, Ron
Thank you.. I do not know the # of tubs I have destroyed as well in remodeling, but later in life we learn if recycling is possible it is a good thing to do, when able of course.
One employee I hired 10 or so years ago, he never put on his tool pouch without having his dremel in it when remodeling.
I be danged if he didn't surprise me each time he pulled that lil bugger out and show me it worked.. And it sure did..
Today with the newer cutting wheels & attachments for them, they become even more handy.
Plantaion shutters as well when the philip type heads are used on the fasteners instead of square or torque heads, he would put on the fine cutting wheel and cut the screws, leaving such a little mark on the trim.
Then later a helper could remove the screws while cleaning the caulking of the edges for install later.
At times a deadbolt keeper will need just a touch of shaving to allow smooth easy locking, run the dremel over it with the grinding stone and works great.
The time & money saved doing this, well worth the tool's cost.
The longer you have one, the more uses you find for it.
Burby is offline
Old 12-18-2008, 06:43 PM   #13
rotarex's Avatar
Re: Tub Removal?
oh yea i forgot to mention this tub was a steel tub, so i ripped the side, i call my steel pickup guy and he takes it away for free and sell, that guy makes from 300-1000 a day, i feel sometime im in the wrong business haha
Custom Decks
Renovation
rotarex is offline
Ballast Removal from EPDM Roof? tekwrytr Roofing 26 06-19-2009 05:12 PM
going rate for tile and carpet removal oldglorydev Flooring 18 09-21-2008 02:26 PM
Plaster Removal Mulecreek Drywall 8 01-16-2007 10:13 AM
pricing wallpaper removal lornmastro Painting & Finish Work 23 09-21-2006 09:40 PM
