Tub Leaking Past Shower Curtain When Shower Is On
Old 10-16-2011, 10:26 PM   #1
smuhhh's Avatar
Trade: Restorations
Rewards Points: 250
Just moved in to a new place and I'm having a problem with the shower in the main bath. It is a one piece tub with a tile surround. The problem is that the tub has a flat ledge all the way around it, about 3 inches deep. The tub is also slightly slopping into the room. Even with the shower curtain closed as much as possible, water hits the ledge and just runs on to the floor. Obviously the tub was designed to have a sliding door system installed. I'm curious if there are any products that are designed to help prevent this? I have seem little suction cup deals that attach to the shower curtain to hold it closer to the wall, but this will only help the problem. I think I need some sort of a weatherstripping track along the front of the tub to stop water. Thoughts? Thanks.
smuhhh is offline
Old 10-16-2011, 10:28 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Tub Leaking Past Shower Curtain When Shower Is On
Aside from band-aids, I see resetting the tub or a glass door as your fix options.
Angus
angus242 is offline
Old 10-16-2011, 10:30 PM   #3
smuhhh's Avatar
Trade: Restorations
Rewards Points: 250
This is just a rental, so any band aid suggestions are much appreciated. Resetting the tub would be a hugely costly ordeal, and I can't say that it would rectify the problem. A shower door would be great, but I don't see that happening unless it is on my dime. Which isn't going to happen.
smuhhh is offline
Old 10-16-2011, 10:47 PM   #4
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 740
There are water dams that fit onto the corners of tubs, to help keep that water directed back into the tub when using shower curtains. Can't find a picture but I've gotten them out of HD before. Peel and stick into place.
It's a quick fix, obviously much prefer doors.
dsconstructs is offline
Old 10-16-2011, 10:52 PM   #5
Rewards Points: 740
http://www.amazon.com/Tidee-Tubb-Spl.../dp/B001A0NA7E
there you go.
Old 10-16-2011, 11:04 PM   #6
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,854
Take baths.
KillerToiletSpider is online now
Old 10-16-2011, 11:27 PM   #7
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Originally Posted by KillerToiletSpider
Take baths.
Or don't!
ohiohomedoctor is offline
Old 10-21-2011, 02:29 AM   #8
Life-Long-Learner
mc handyman's Avatar
Trade: Home Repair & Remodeling
Rewards Points: 150
Had the same problem in a rental unit a few years ago. These work great... assuming your curtain blocks most of the water.
http://www.amazon.com/Spraymaid-Bath.../dp/B00065XS9Y
If you are afraid of criticism, you will die doing nothing.
mc handyman is offline
Old 10-21-2011, 05:19 AM   #9
General Contractor
greg24k's Avatar
Rewards Points: 7,024
Get a splash guard, something like this... rubber duck is not included, you will have to get your own.
If not, send your landlord an email or a letter, tell him the tub is installed incorrectly and it floods the bathroom, maybe he give you the job in exchange for rent.
greg24k is offline
Crack in prefab shower pan. Can it be repaired? wopachop Plumbing 30 09-30-2011 09:26 AM
DIY shower...had to "share" jarvis design Tiling 12 04-17-2011 02:49 PM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 09:42 PM
care to share ideas for 2 person shower? AustinDB Tiling 12 02-24-2009 01:47 PM
leaking shower dlcj Tiling 18 10-09-2008 11:20 AM
