Tub Install And Drain In Slab
I usually do not do much bathroom work however a renovation I am working on has a leaking shower stall. I am planning on ripping out the shower stall, fixing the water damage and installing a tub in place. The drain for the shower stall is in a bsaement concrete slab. I am going to frame a base for the tub which would raise it 4". This base would also extend past the tub for a step into the tub. This will also provide clearance underneath the tub to connect into the exisiting drain pipe rather than remove concrete. I will have my plumber hook up supply lines and drain pipe after the base has been installed. Does this sound like the best approach or should I move the drain in the concrete to vertically align with the concrete.
It's all about the Avatar
Trade: I have no face!
Re: Tub Install And Drain In Slab
It really does not take that long to jack hammer out the drain have it connected correctly. Your tub is typically a 1 1/2" waste and over flow and the shower is typically 2". Have your plumber come over and recommend. A raised tub in a aready low cieling in a basement may look home owner installed. And climbing stairs to a tub should be keeped for holiday resorts, not to functional.
#3 | |
Trade: plumbing
Re: Tub Install And Drain In SlabQuote:
| TnP drain line with company | JamesNLA | Plumbing | 4 | 12-05-2006 07:28 AM |
| drain tile question | bobbrown | Construction | 5 | 09-05-2006 07:52 AM |
| over flowing drain | earl hall | Plumbing | 6 | 10-31-2005 02:07 PM |
| Drain Vent Question | straitlineguy | Plumbing | 2 | 11-24-2004 08:23 AM |
| Basement bath install | MinConst | Plumbing | 7 | 11-18-2004 10:34 AM |
