Truly Shocking!
Old 03-13-2008, 09:28 PM   #1
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
Truly Shocking!
What can you do to safeguard against getting shocked in a wet crawlspace? (need interesting answers for a class). Beside the obvious, like GFCI on your power source. ANY GOOD STORIES?
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 03-13-2008, 10:51 PM   #2
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
Re: Truly Shocking!
What I do is if there`s any question about having to crawl over any power lines I pull the meter.
Now if` I`m just working by a line I look it over and again, "if I have ANY question about the condition of the line I pull the meter".
If the crawlspace is flooded I pull the meter because you cant see a line under the water or under ground that's under the water.
The Power CO would rather have you cut the tag off and pull the meter then have the EMS pull a dead plumber out of a crawlspace
Oh and if the crawlspace is flooded I use my cordless tools and lights
Save your life and think TWICE
www.all-clear-sewer.com
All Clear Sewer is offline
Old 03-15-2008, 07:30 PM   #3
Herk's Avatar
Trade: Plumbing
Re: Truly Shocking!
One really good way to get killed is to disassemble a pipe under a house, for example, to replace a valve. This is especially true in older homes. The pipe may be the only ground in the house's electrical system. If you have to do something like that, use electrical clamps and a heavy (like #2) wire between the clamps before you disconnect anything. Otherwise, you, laying in the wet ground, become the system ground.
There are no dumb questions - just a lot of inquisitive idiots.
Herk is offline
Old 03-15-2008, 10:32 PM   #4
smellslike$tome's Avatar
Trade: plumbing
Re: Truly Shocking!
Jumper cables.
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
Most Shocking Magnettica Electrical 8 02-06-2008 11:03 PM
shocking discovery... rigid sander and vac... fastg60 Tools & Equipment 8 01-13-2007 09:42 PM
Shocking Truth about GEC's JoeTedesco Electrical 8 01-06-2007 02:53 PM
Shocking.......... Peladu General Discussion 2 01-19-2006 07:57 AM
