Trouble Sweating Onto Old Copper
Old 07-11-2005, 09:20 PM   #1
Remodeler
MinConst's Avatar
Rewards Points: 502
Is there a trick to this? I have no problem sweating new copper but when I have to tie into old copper pipe I have a hard time getting a good joint.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 07-11-2005, 10:21 PM   #2
plumguy's Avatar
Trade: plumbing and heating
Rewards Points: 250
Re: Trouble Sweating Onto Old Copper
Obviously, with old copper there is more cleaning with sandpaper involved. You must get it clean and shiney and use a good quality flux. If you are tying into an existing system then you might be having a water problem and need to drain the system a little more. Other than that everything is pretty much the same.
plumguy is offline
Old 07-11-2005, 10:37 PM   #3
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
Clean it, Clean it, Clean it, wire wool, emery cloth, flux, whatever it takes, if you're down to NOTHING but copper it'll work.
reveivl is offline
Old 07-11-2005, 11:42 PM   #4
Custom Builder
Glasshousebltr's Avatar
Rewards Points: 2,000
Old coppers been on the beat a long time, it's tough to make them sweat.
Bob
Bob
Glasshousebltr is offline
Old 07-12-2005, 04:00 AM   #5
Bjd's Avatar
Rewards Points: 250
Try tinning the joints before you sweat them, by heating the area and appling flux to the heated surface. Then add a little bit of solder and see if it runs completely around the area, clean again with fine steel wool and you are ready to apply the fittings.
Its as simple as 1 2 3
BJD
Bjd is offline
Old 07-12-2005, 05:07 AM   #6
Remodeler
MinConst's Avatar
Rewards Points: 502
I will try the tinning. What I see is that the solder does not flow. I have to heat the ******************** out of the joint and even then it doesn't seal. I guess it might be that I'm not cleaning enough. Thanks for the tips. I will try them.
Paul
Website
MinConst is offline
Old 07-12-2005, 06:00 AM   #7
GMW's Avatar
Trade: Deck builder & Handyman
Rewards Points: 75
If by old copper you mean existing, it could be water still in the lines. That has happened to me several times. It doesn't take much water for it to mess up a joint. Even if it seems dry, heating up the pipe can cause water to appear. I have used the white bread trick several times with great success. Good luck.
Also do you guys use propane or mapp gas? I switched to mapp gas and have had better luck since. Thanks.
GMW is offline
Old 07-12-2005, 06:38 AM   #8
plumguy's Avatar
Rewards Points: 250
If you're using excessive heat, either it's not cleaned properly or you're getting water. Too much heat wiil also burn the flux and effect the flow. I don't recommend tinning and it certainly isn't as easy as 1 2 3. But, they do make a self tinning flux.
plumguy is offline
Old 07-12-2005, 06:43 AM   #9
plumguy's Avatar
Rewards Points: 250
I use propane. I was introduced into the trade with it by an old timer and never had reason to switch. It comes down to personal preferance. Although, I have noticed a lot of guys apply too much heat when they are using mapp.
plumguy is offline
Old 07-13-2005, 04:32 AM   #10
Bjd's Avatar
Rewards Points: 250
I am forth generation in plumbing and heating, for some reason I prefer the Actlyenne gas with a soft flame tip for my small stuff.
We carry very large bottles on our rigs with 50+ feet of hose, for small repairs we also carry MC bottles.
When we are doing large scale work we will switch to turbo, and use the big bottles as its much cheaper than swaping out B tanks.
Having these big bottles also allows us to, if need be just add OX bottle switch lines then we are set to either burn, or braze.
At times this can put us over the edge, like in large copper water main repairs, 3 - 4 in size as they require a lot of heat to complete the joint with us carrying the mix gases we can do these pretty quick.
BJD
Bjd is offline
Old 07-13-2005, 11:37 PM   #11
Teetorbilt's Avatar
bjd, small wonder that it costs so much to live up there! 3-4" copper mains? That's mindbogolling to me.
Here, the grid is 6" ductile iron with fire services.
Albert Einstein
Teetorbilt is offline
Old 07-14-2005, 12:30 AM   #12
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
You may have considered this but some H2O in the line makes steam pressure and if it has no release it will push out through the last joint. It took me a few days to learn that as a young bootleg plumber. I noticed the real plumbers didn't spend so much time on a joint and never built up pressure. For a while I always made my last joint a union but now a open valve does the trick.RT
K2 is offline
Old 07-14-2005, 03:55 AM   #13
Bjd's Avatar
Rewards Points: 250
Most of our large diameter mains are inside, as the codes in Mass are crazy about the water main sizes.
Its kinda of funny years ago the largest water main for a res home was 1" copper, today with the size of new homes its nothing to see a 1-1/2 water main.
BJD
Bjd is offline
Old 07-14-2005, 05:13 PM   #14
Custom Builder
Copper?......On the beat?....get it?.....whats a guy gota do for a drum roll around here?
Bob
Bob
Old 07-14-2005, 06:41 PM   #15
plumguy's Avatar
Rewards Points: 250
Bob
I missed that one! I'll have to remember it! :Thumbs:
plumguy is offline
Old 01-11-2006, 03:36 PM   #16
Plumbing Contractor/Owner
SosaPlumbingInc's Avatar
Trade: Plumbing Contractor -C36
Are you installing tank-less water heaters in your area?
Jorge E. Sosa:
SosaPlumbingInc is offline
Old 01-11-2006, 04:26 PM   #17
jmic's Avatar
Seems like whatever you do these days is tankless.
Joe
jmic is offline
Old 01-11-2006, 08:53 PM   #18
locofoco's Avatar
Trade: general remodeling
Rewards Points: 75
Rob53 & GMW are right -any water in the lines spells big trouble.
locofoco is offline
Old 01-11-2006, 09:16 PM   #19
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
Rewards Points: 578
i know this is wacked but water problems in a line can be helped by stuffing some BREAD in the line, fluxing, then sweating (pre sanded of course). you got to pull the areator out of a faucet to get the crap out. i know its one of those old timers/ last resort things
go dart is offline
Old 01-11-2006, 09:48 PM   #20
Deck Designer/Builder
DecksEtc's Avatar
Bob
Ba dump bump!
There's your drum roll Bob!
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
pex vs. copper Mr. D Plumbing 68 05-16-2008 10:46 PM
Aluminum to copper lug Mike Finley Electrical 21 06-02-2007 11:31 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 08:39 PM
Copper vents -vs- plastic/aluminum shopman Roofing 2 03-01-2006 07:51 AM
Sweating copper pipes MikeF Plumbing 2 03-03-2004 11:28 AM
