Unregistered
Guest
Posts: n/a
Too Much Pressure
I have just installed a whole house pump rated at 2.2 bar.
Its for a friends house with one ensuite shower and main bathroom shower. I didn't want to run an individual feeds from the hot and cold tanks to supply them so I thought it would be easier to pump the house house. The problem is its too powerful, so the hot water tank gets empty in 3 showers. Any ideas to reduce the output. I thought of putting gate valves on output pipes, will this damage the pump? Or is there a electrical methed that I could reduce the pump speed, such as a variable resister? |
Re: Too Much Pressure
Try a whole house pressure regulator from Watts
# U-5-B it will lower the pressure and extend the water from the tanks. ? What is the PSI are you running? What size are the tanks? What is the temp on these tanks? Bernie |
Unregistered
Guest
Posts: n/a
Thanks Bernie
Would I fit one of these to the output of the cold and hot from the pump. Not sure about the psi the pump is quoted at 2.15bar, which I think is about 31psi. The cold water tank is 120 litres and the hot water I think is 115 litres and the hot water temp is set at 60 degrees celcius. cheers sean. |
Guess I will have to get a conversion chart, but too answer your question yes you would install such a regulator on the water main before the hot water tank.
Bernie |
Unregistered
Guest
Posts: n/a
I think you have overlooked a bigger problem. You expect 3 showers with a 30 gallon tank (back to back i suppose)? Pressure isn't your problem, volume is. 30 P.S.I. for a domestic pump system is adequate (barely). If you drop the P.S.I., you will be able to pee harder than the shower. Want more showers, get a bigger water heater.
| Pressure washing 2300 sf concrete | pitterpat | Pressure Washing | 13 | 09-28-2010 08:16 PM |
| advice on low pressure well problem | 72chevy4x4 | Plumbing | 0 | 07-16-2007 07:54 AM |
| pressure washer | Traditions | Painting & Finish Work | 10 | 05-06-2007 11:54 AM |
| Lennox Pressure Switch Trouble? | Glock23 | HVAC | 1 | 01-03-2007 10:25 PM |
| water pressure with on demand heaters | Vermonster | Plumbing | 2 | 11-11-2006 07:14 AM |
